Originally Posted by greatgaz
I have just bought a new Wharfedale L1911W-A TV. I cannot find the right code for my sky remote to work for my TV (Volume etc.) I have tried various internet sites and none of the codes seem to work. Could someone please help me and give me advise. Thanks
Have you tried 0065 if so are you doing it correctly
1.Press TV on sky remote
2.Press select and red button at the same time (red light blinks twice)
3.Enter the code 0065? ( red light blinks twice)
4.Press select, then standby(TV should go off)
If it does no go off try pressing TV before you enter the code
Good Luck
PS. if it does not work it might be your Sky remote, what version is it
