AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 03-04-2007, 6:32 PM   #1 (permalink)
Angry My no2 LNB wont lock
hello can you help me my box will not lock on signal no 2 it is a new lmb and cable i cannot recorde on my sky plus and it is freezing for a few seconds about 5 thanks alot darren
dazpem is offline
Old 03-04-2007, 8:42 PM   #2 (permalink)
Thanks: Gave 2, Got 107
Re: My no2 LNB wont lock
Swap feeds 1 & 2 over. If the fault has not switched to input 1 then the tuner (2) is failing. A replacement box will be required unfortunately.
Cheers, Franc
FRANTIC FRANC is offline
Old 04-04-2007, 2:31 PM   #3 (permalink)
thanks frank hi will try to get a new box and get rid of this amstrad
dazpem is offline
lnb, lock, no2
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
