AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 03-04-2007, 12:10 PM   #1 (permalink)
Thanks: Gave 3, Got 0
Second TV From a Sky Box
Currently I have two boxes (one in each living room).
I want to connect my bedroom TV up to the second box that doesn’t get used so much.
Is it easy to do, what do I need?
Does this work?:
http://www.maplin.co.uk/Module.aspx?...REMOTE&doy=3m4
Will I need a signal booster, such as:
http://www.maplin.co.uk/Module.aspx?...ooster&doy=3m4 ?
Potato Pirate is offline
Old 03-04-2007, 6:49 PM   #2 (permalink)
JayCee's Avatar
Thanks: Gave 73, Got 741
Re: Second TV From a Sky Box
You need to run a length of coax cable from the Sky box RF2 outlet to the TV.
The TV Link will allow you to remotely control the Sky box.
You shouldn't need a booster amp unless it's a very long cable run.
JayCee
Please note that any views expressed are my own personal opinions and not those of the AVForums
JayCee is offline
box, sky
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
