Fitted new HDD but capacity not showing full amount
Earlier today I fitted a 250GB Samsung drive to my Sky+ box. I had a little bit of trouble setting the cable select set correctly, and originally the drive wasn't even recognised. It then was seen as a 32GB drive!!
Eventually I thought I had it sorted, but I set it to record a 1hr program and this said it would use 2% of the drive. I set it to record a 2hr programme and this said it would 3%.
By my calculations this would allow a max recording time of 66hrs - which would mean drive is being seen as approx 120GB.
Can anyone advise as to what I may have done wrongly?
I'm guessing it is connected to the cable select setting - can anyone who fitted a similar Samsung advise as to what they set it at.
Thanks.
