AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 08-08-2006, 12:53 PM   #1 (permalink)
WelshBluebird's Avatar
Thanks: Gave 41, Got 150
Widescreen image seems streched
Right, I've had freesat from sky installed over the weekend, and I'm loving the choice of channels I have now got (never had digital before, only anologue terrestrial).
However, I have a widescreen TV, and the box is set to output a 16:9 image, however it looks a bit stretched vertically (and people seem to have long faces etc). The only way I can make it look like the anologue channels looked like is by stetting the box to output a 4:3 letterboxed image, then zoom in a bit, so I don't see the bars.
I have read on another forum, that the only reason it seems stretched vertically, is because I've because used to watching the analouge broudcasts streteched to fill the widescreen TV. Is this true?
btw, I could take a picture using my digi cam, and post it up if that would help.
WelshBluebird is offline
Old 08-08-2006, 12:58 PM   #2 (permalink)
Thanks: Gave 16, Got 149
Go on; I will give an opinion; for one
System 1 Panny TX-36PF10; Topfield PVR; Arcam DV88; Musical Fidelity X-A100R; Yamaha DSP800; Castle Harlech; Rega Planar 3; MF ; X-24K DAC; phono amp; headphone amp; & XPSU ; Sennheiser HD600; Harmony 885
System 2 LG Flatron MW-30LZ10, Topfield PVR; LG Video/DVD combo; Yamaha RX-SL80. Harmony 655
Richard46 is offline
Old 08-08-2006, 1:11 PM   #3 (permalink)
Cheers.
For some reason, it doesn't seem to look as stretched in the pic (thats probably just me tho lol).
Here's the pic (It's corrie I know , It was the only channel out of the first 3 that had a face on lol)
http://img82.imageshack.us/img82/4653/cimg1664ec0.jpg
edit - another thing I've noticed is that on BBC1, BBC2 and News 24, whenever there is a peice of prerecorded news (as in, not someone in the studio presenting the news), there is a area to the right where for some reason the piocture doesnt' extend to, but the news bar at the bottom does. I've got a picture of that aswell.
http://img397.imageshack.us/img397/4404/cimg1665yz8.jpg
Old 08-08-2006, 1:20 PM   #4 (permalink)
Bit difficult to tell with our Sawphie who is stretching her own face anyway but Sally does look distorted to me. As you say a picture stretched vertically would be my judgement from that pic anyway.
Old 08-08-2006, 2:34 PM   #5 (permalink)
Thanks: Gave 0, Got 34
It's normal for prerecorded news footage not to fill the screen all the way to the right on News24. Your News24 picture looks ok, but the ITV one does look a bit odd. Have you got the Sky box connected via SCART from it's TV output socket into the AV1 scocket on the back of the TV. In this case an aspect signal will be sent, and the TV's aspect will be set to exacty what's required.
Other than that, you may indeed have gotten too used to stretched faces on analogue :-)
Owain.
ows90 is offline
Old 08-08-2006, 3:08 PM   #6 (permalink)
Thanks: Gave 16, Got 279
What TV is it and what aspect ratio/wide mode have you got set on the TV?
neilmcl is offline
Old 08-08-2006, 3:14 PM   #7 (permalink)
Thanks: Gave 0, Got 26
I've got a sneaking suspicion that the TV may have a 1280 x 768 panel ie 15:9....
Andy3 is offline
Old 08-08-2006, 3:22 PM   #8 (permalink)
It's a Thomson TV, although I'm not sure of the model though . I'll have a look later to see if I can find the manual.
I probably should have mentioned earlier, its CRT (and if I'm right, CRT's don't have set resolutions??)
I did have it set to auto, and I just tried forcing it to 16:9 aspect ratio, and nothing changed, so I'm guessing it is getting the right aspect ratio info from the sky box.
Btw, just been playing around now. I had a look at the analogue channels again. But instead of letting it stretch the image to fill the screen, I forced it to show the image in a normal 4:3 size with bars down the sides and and along the top and bottom. I then turned back over to sky, and back over to analogue, and apart from the size and shape of the image, it seems the same (ie - with what I felt the image stretched vertically).
So it seems it was just me used to the TV stretching the analogue image to fill the screen.
Old 09-08-2006, 1:30 PM   #9 (permalink)
A Quick update here.
I turned off everything, unplugged the scart cables etc, then plugged everything back in and turned them back on. And now it seems normal with no vertical stretching. So I dunno what was up there lol.
Cheers to those who've posted.
image, streched, widescreen
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
