AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 13-07-2006, 8:38 AM   #1 (permalink)
Thanks: Gave 0, Got 2
phoning sky from abroad
What is the best way to phone sky from abroad without sky being able to see my phone number.
colin h is offline
Old 13-07-2006, 8:46 AM   #2 (permalink)
Thanks: Gave 69, Got 314
Get your auntie to do it ?
Nick_UK is offline
Old 13-07-2006, 10:12 AM   #3 (permalink)
gavan's Avatar
Thanks: Gave 135, Got 109
You could try using something like Skype or one of the other 'telephone from your PC over the internet' applications ... If they ask you why they are getting a weird CLID number then point out that this is just the way that Skype works. Of course, you are using Skype because you get really cheap calls and therefore don't have a landline...
If they still are stroppy, then tell them to call you back on your UK mobile number (assuming you have one available). They have no way to know that you are out of the UK, though you could pick up quite a hefty roaming bill if the call takes a while.
Gav
gavan is offline
Old 13-07-2006, 3:40 PM   #4 (permalink)
They could well notice the dialing tone of the mobile is not a normal UK one if you got them to call it.
Email them & tell you're deaf, ask them to deal with your query via email.
mcfisco is offline
Old 15-07-2006, 7:16 AM   #5 (permalink)
Thanks Gavan I phoned using skype and had no problem
colin h is offline
abroad, phoning, sky
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
