AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 11-07-2006, 7:08 PM   #1 (permalink)
Thanks: Gave 0, Got 12
Video Overaly on RGB Issue...perhaps..?
ok, forget about component and HDMI for a minute and focus on the scart (RGB)..
I've noticed some instability with the video overlay (synopsis/search&scan banner etc) on SD channels. (not menus/EPG)
The outer border and text seems to twitch a little like their's an interlace problem.
Also on some scenes, the picture movement seems to influence the video overlay resulting in a slight wobble of the text itself..
These effects seem to have a pulsing motion similar to a continuous resync cycle.
I had never noticed this on my PV500 with my Pace Sky+ box and can confirm it's restricted purely to the scart.
No other RGB equipment (over the same scart via a switch) exhibits this behaviour either..
(& yes I've tried the box direct and it's not the switch)
It's been happening for a little while now and it's getting on me tats now
Anyone else notice overlay issues via the scart in RGB?
CG121 is offline
Old 11-07-2006, 10:01 PM   #2 (permalink)
Thanks: Gave 0, Got 10
Dont see thios problem on my normal HDTV, but have one of the scart outputs sent via digisender to another SD TV. When I display any of the sky banners on that screen the screen goes out of sync slightly and I get a buzzing noise.
davybaker is offline
Old 19-07-2006, 1:50 PM   #3 (permalink)
That's because your main TV is connected via HDMI..
That'll be the digisender...
As for the 'twitchy' graphics, can we assume then this is not a problem for those watching SD material in RGB from the TV Scart....?
That would make my box faulty (Hardly a surprise though lol)
CG121 is offline
Old 19-07-2006, 5:42 PM   #4 (permalink)
StooMonster's Avatar
Thanks: Gave 122, Got 264
I've noticed this about the 'search & scan' banner in the past with my old Sony stb, and Sky+ and with Sky HD too. e.g. the top of the box can flicker if anything big and bright goes near it.
Definately doesn't happen on HDMI though.
StooMonster
Status: studying on my Masters again, no time for AV.
StooMonster is offline
Old 19-07-2006, 6:25 PM   #5 (permalink)
JagoPlasma's Avatar
Thanks: Gave 394, Got 177
if your reffering to what i think your reffering to then you have just stumbled onto the only drawback of rgb scart (other than lack of HD)
anything that has strong white horizontal lines and text will give you this effect, its mostly notable on DVD menus, video games and video overlays.
its just how it is im afraid, try turning your contrast down as it is probably too high
EDIT: are you talking about a CRT screen btw?
GAMERTAG&PSN: WilmaDicfit
DISPLAY: 42PX60 TV Source: Sky HD WD1TB
CONSOLES: PS3 HDMI 1080p, XBOX 360 with HD-DVD Component 1080i, Wii Component 480p
Other Equipment: Iphone 16GB, Sony HDR-SR12E, Linkstation Live 1TB, WD Mybook 1TB
JagoPlasma is offline
Old 19-07-2006, 7:54 PM   #6 (permalink)
I've seen it with Sky HD box set to LOW contrast, and with ISF calibrated screen; furthermore, can see it when deinterlaced by expensive external video processors too. Never noticed it on CRT.
Not visibile on all strong white horizontal lines and/or text, only top pixel line of Sky 'now & next' banner bar.
StooMonster
Old 20-07-2006, 8:14 AM   #7 (permalink)
I only noticed the 'twitching' on the text itself on the HD box, the Pace V2 Sky+ never had any such issues over RGB on my PV500..
The text was stable and certainly didn't wobble on some scenes..
I've always ignored the initial line (top) of the overlay, as that's merely an interlace issue, but wobbling and twitching text are new to me....
It certainly is not exclusive to high contrast scenes, standard scenes cause the entire overlay to wobble like jelly and the twitching is best described as a slight vertical shake due to a suspected interlace issue..
I feel a phone call coming on
CG121 is offline
Old 20-07-2006, 10:33 AM   #8 (permalink)
As I said before I dont see this on my main TV even when viewing the SCART output on my main TV!!
It is seen via the digisender still.
Old 20-07-2006, 1:39 PM   #9 (permalink)
Thanks for that.
I would hate to get a reputation as a $ky hater....
So I'll try another monitor before calling in the "$ky Engineers" pmsl..
CG121 is offline
issueperhaps, overaly, rgb, video
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
