Originally Posted by neilmcl
Bad advice.
No, good advice and accurate to boot. I've installed hundreds of these things so I should know.
If he's still within a 12 month contract then he's required to have the phone connected to a telephone line for the duration of the contract .
"Required" maybe, but this is never checked. So why worry about it? Do you slavishly do everything that you are "required" to do?
and if he's got multiroom he should have the line connected all the time. How his anyone supposed to know which days of the month, night or day, when Sky calls up to check the connection.
Sky do not call the boxes at any time, ever.
A signal is sent via the satellite to both boxes on a regular basis and they then call Sky. If they can't get through they try more and more often until they can. Sky do not chase up missed multiroom calls until after many weeks so connecting the two boxes overnight once or twice a month will be perfectly adequate.
It seems fairly likely from his message that the OP doesn't have multiroom anyway and so he can just unplug the phone and forget about it, as I suggested.
