AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 23-03-2006, 10:00 PM   #1 (permalink)
caithpal
Posts: n/a
Angry Poor Picture Quality from Sky + with Philips 32DW6559
Hi I have just "upgraded" from a 28" widescreen panasonic TV to a 32" widescreen, pure flat etc philips (model - 32DW6559). The picture quality from the built in digital tuner is fantastic and I receive all the usual freeview channels etc. The only piece of equipment I have connected is a Sky + box which is 1 month old. When I flick between the Digital tuner and the sky + source the picture quality is hugely different. Sky appears slightly ghosted and is not good at all. It is shimmery when there are blocks of solid colour and in general the resolutions is very poor. I tried playing with the settings and spent over an hour on the phone to sky but the picture quality is still rubbish. I have checked the scart and used 3 different ones with no success. I even made sure it is connected to the correct RGB enabled SCARt socket. Any ideas as this is really driving me mad and the wife isn't happy as when I plug in the old tv the picture quality is back to normal!
HELP
Old 23-03-2006, 11:38 PM   #2 (permalink)
JayCee's Avatar
Thanks: Gave 73, Got 741
HELP
Has the digibox been set to output RGB within the "System Setup", "Picture Settings" menu, you should see a definite shift as you toggle back and forth between "Pal" and "RGB"?
JayCee
Please note that any views expressed are my own personal opinions and not those of the AVForums
JayCee is offline
Old 24-03-2006, 6:50 PM   #3 (permalink)
caithpal
Posts: n/a
Hi thanks for your reply. I have ensured that it is set to RGB. On PAL it is terrible quality. Could it be the SCART?
Old 24-03-2006, 7:11 PM   #4 (permalink)
JayCee's Avatar
So you do see a noticeable difference when the menu is on-screen and you switch back and forth between PAL and RGB?
Poor quality scart leads can introduce "ghosting/ringing" effects in the picture.
Make sure the scarts are "individually screened" types rather than "overall screened" types...the thicker the lead the better is a good indication of quality.
JayCee
JayCee is offline
Old 24-03-2006, 8:38 PM   #5 (permalink)
caithpal
Posts: n/a
there is a big difference between PAl and RGB when I change the settings. I have a cheap £2 ish SCARt and a slightly more pricy £5 SCART that I got from ebay and the £5 one is slightly thicker and I get better quality. I'm guessing this is the problem. Would anyone recommend a particulalry good SCART or are they all pretty similar if I spend a bit more?
32dw6559, philips, picture, poor, quality, sky
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
