AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 22-03-2006, 8:32 PM   #1 (permalink)
Which Sky+ Box??
Hi all,
I'm scheduled for a Sky+ install on Monday.
Which box is best? I see that Pace get good things said about them. Are they all pretty much the same?
I have a 32" Samsung HD LCD TV, so would like the pic quality to be as good as poss.
Would you reccommend using S Video for this? Composite?
Do any of them have component out?
Many thanks!!!
rythmix is offline
Old 22-03-2006, 8:50 PM   #2 (permalink)
Do you not want to wait for the new HD box to come out, are you a new subscriber to sky as history shows that as a new customer you get better deals, so if you get a new box now when HD does come out you will be treated the same as the rest of us, ive been putting off getting sky+ until HD comes out as i dont want to pay for a box now and then have to pay again for new HD box, also when you get a new Sky+ box do you have to take out a new 12 month subscription, as if so im definately waiting as im currently out of my 12 months so I have better bargaining when HD comes out
kwaboy is offline
Old 22-03-2006, 10:17 PM   #3 (permalink)
Thanks: Gave 69, Got 314
You don't usually get a choice of box if the install is arranged via Sky, although if the installer has been allocated a batch of boxes, a cup of coffee and a friendly chat can often bring you the box you want. RGB via scart or s-video would be the best connection method - there are no boxes with component out.
Nick_UK is offline
Old 23-03-2006, 8:37 AM   #4 (permalink)
Thanks,
So would you go for a Pace if poss?
From looking at the Pace and Amstrad they look the same! Is it just the internal components which differ?
Ta
rythmix is offline
Old 23-03-2006, 8:50 AM   #5 (permalink)
Thanks: Gave 758, Got 89
Yes and I think the viewing card slot is on the oposite side too.
I have my sky+ connected to my panels vga socket as this gives the best picture IMO, you will need a RGB to VGA convertor for this though + associated leads (costs around £150-£200 depending on how much you spend on the leads).
If you want a cheaper option then buy a good quality scart lead and use the RGB scart connection.
Fusewire is offline
box, sky
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
