21-03-2006, 11:58 PM
#1 (permalink)
Sky digital message error
Hi Guys i want to ask a question about sky digital ... well i have a sky digital box and card , which i was using 6 months ago and then i got disconneted that connection and now i was just trying to connect it agian with my dish to watch fre view and Receiving message "NO sattelite signal" , but i pluged with 2 diferent dished but message was same .... what sort of problem it could be my card is been blocked or some thing else ... any suggestion please .
Thanks.
22-03-2006, 1:08 AM
#2 (permalink)
Thanks: Gave 87, Got 632
If the box is giving that message on a number of different dish/lnb feeds in different locations that work on other digiboxes then it sounds like the digital tuner is busted. If there was a problem with the card you would still get the FTA channels and a populated EPG.
"The Nac Mac Feegle are, well, they’re like tiny little Scottish Smurfs who have seen Braveheart altogether too many times."
22-03-2006, 3:16 AM
#3 (permalink)
if digital tuner is busted then i should not receive any message or i should see any thing else it show me sky listing, and main message is no sattelite signal, what do u think it could be problem with the card or some thing .?
22-03-2006, 8:42 AM
#4 (permalink)
Thanks: Gave 73, Got 741
It could be the dish connection or faulty LNB, nothing to do with the card.
JayCee
Please note that any views expressed are my own personal opinions and not those of the AVForums
22-03-2006, 8:45 AM
#5 (permalink)
Thanks: Gave 69, Got 314
As Starburst said, if you have connected it to two different dishes and are still getting the "no signal" message, then it's probably the tuner that's at fault. You won't get any listings, because you won't be receiving them. Of course, it's possible that you've connected the box to 2 faulty dishes, was the second dish on a working system ?
22-03-2006, 2:33 PM
#6 (permalink)
i recenlty move to this house and found 2 old dished out side my house and i can see cables are comming in to my window just trying to connect with digital box but on both dished mesage was same, one of my friend told me that we used to have ntl on this house, but i couldnt find any solution , might be dishes not woring properly.
any suggestion
22-03-2006, 3:16 PM
#7 (permalink)
The dishes could be old Sky analogue ones, which would be aimed at the wrong satellite. Try taking your box to someone you know that has a working Sky system.
