AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 24-02-2006, 10:20 AM   #1 (permalink)
Thanks: Gave 6, Got 2
I think my SKY+ box is dying
Guys I need some advice, my parents Sky+ box has failed twice now and wiped all the programs off the hard drive (which is well anoying). What I mean by failed is that it just turns off randomly and then when you try to turn it back on does not turn on and stuck in standby. The second time it did it, we could get into the menu but when selecting a channel it would screw up and lock up. On both occasions when we got it working again it said there was a fault with the hard drive and it would not record and we had to ring sky. I did a hard drive reset which seems to cure the problem but only in the short term. We rang sky and they give you the usuall troubleshooting rubbish that any person with a technical savvy can do.
Should we be more forceful with sky? they said it would cost £65 for an engineer to come out and look at it as its outside warranty (2 years old). However I think its down to their recent software upgrade thats killing the sky+ box
What should we do? what did you do when you were in the same situation?
bogbloke is offline
Old 24-02-2006, 11:11 AM   #2 (permalink)
Thanks: Gave 1, Got 6
I had the same problem, apparently the upgrade created this fault on a lot of boxes I was told by customer services. Sky changed my box and the Engineer told me that he was changing at least 4 boxes a day.
Get back on to them, in the mean time try doing a full system reset / planner rebuild, this cured mine for a few days until the engineer arrived.
LG 42PX3RV Plasma, Yamaha DSP-AX750SE AV Amp, LG DVX 9900H Dvd Player, Sky+, Panasonic DMR EX75Digital Recorder, XBox 360, Wii and Playstation 3. Oh what to buy next.
A5tra_G is offline
box, dying, sky
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
