AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 22-02-2006, 3:16 PM   #1 (permalink)
tigger78
Posts: n/a
Sky+ Box fault today
Any help will be appreciated.
No Sky this morning, standby light resolutely red. Phoned Sky (after removing plug and waiting - as per standing instructions) who downloaded data via the phone line. Did not work after this so an engineer is calling (Saturday).
Is there anything else that I should try?
Also if they change the box is there any way that I can recover the hours of stored programmes on the hard drive? I did note a couple of USB ports.
Thanks.
Tigger78
Old 22-02-2006, 3:34 PM   #2 (permalink)
throwit's Avatar
Thanks: Gave 53, Got 16
sounds a bit like what ours used to do on occasion
have you left it unplugged a good while and tried again ?
may take a few goes, but it may work - that's about the only thing i can help with
good luck
throwit is offline
Old 22-02-2006, 10:35 PM   #3 (permalink)
tigger78
Posts: n/a
Thanks - will give it a try.
Any other ideas will be very welcome.
Old 23-02-2006, 8:27 AM   #4 (permalink)
Thanks: Gave 12, Got 23
What make is the box?
Cupart is offline
Old 23-02-2006, 10:41 PM   #5 (permalink)
tigger78
Posts: n/a
It is a Thomson DS16210. Is there a history of problems with this one.
Thanks for your help.
Tigger78
Old 24-02-2006, 8:59 AM   #6 (permalink)
Don't know about the Thomson box, but know that there are problems with the Amstrad's...
Could you please post the verdict after the sky person has been out looking at the box?
Cupart is offline
box, fault, sky, today
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
