AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 20-02-2006, 8:41 AM   #1 (permalink)
Thanks: Gave 161, Got 26
Sky+ ghosting new install
Hi all,
Just moved house and had my existing Sky+ re-installed.
Have noticed though, that there is a little ghosting moving from left to right like a line when watching Sky. Everything else (Xbox, DVD etc) seems unaffected.
All the settings are okay and cabling all tight, anybody got any ideas? The setup at my other house was okay.
TIA?
CatManDo is offline
Old 20-02-2006, 9:27 AM   #2 (permalink)
skytecbvmo's Avatar
Thanks: Gave 81, Got 65
Originally Posted by CatManDo
Hi all,
TIA?
use a better shielded scart lead this will get rid of your problem
skytecbvmo is offline
Old 20-02-2006, 9:30 AM   #3 (permalink)
i thought about that, but I can't see how it can be the scart cable because:
I have a Joytech Scart control center, everything (Sky, DVD, Xbox) plugs into that and then one scart goes to the TV. All the other items are okay and all the scart cables are the same as I had in the previous house, with one exception.....due to location I had to buy a 4M scart cable that goes from the TV to the control center as my 3M one was not long enough. Now if it was that cable that was faulty, then surely I would have the same problem on DVD and Xbox feed.
Does that make any sense?
CatManDo is offline
Old 20-02-2006, 10:36 AM   #4 (permalink)
JayCee's Avatar
Thanks: Gave 73, Got 741
The cable is probably not "faulty" just poorly screened.
Can you try the original scart back on it to prove the point.
JayCee
Please note that any views expressed are my own personal opinions and not those of the AVForums
JayCee is offline
Old 20-02-2006, 10:37 AM   #5 (permalink)
I will try the original scart tonight to see if it makes a difference.
The new scart cost me £40 from Comet, I think its a Monster one! Its all I could find in that length in a hurry!
CatManDo is offline
ghosting, install, sky
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
