AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 10-05-2001, 9:19 AM   #1 (permalink)
KAO
Posts: n/a
Post Sky Program Planner
From my man in Bavaria...apparently this hasn't been officially announced by Sky yet. I have an early Pace box but I've not checked if the update has happened...anyone else seen it yet?
More information on the new Sky Programme Planner.
Currently Pace are the only digiboxes to be receiving this download, which
takes place automatically, usually at night. The new software version is
denoted 1.2S4Ba (EPG Software 2.7bb.5). Some older Paces have been
reported to experience problems such as freezing or loss of sound, which
is fixed as usual, with a hard reset (power cycle). No doubt a further
download will fix these issues in the fullness of time.
The programme planner allows the viewer to be reminded one minute before
the start of a selected programme, and to optionally automatically change
channel (e.g. to allow a VCR to be set up to record it - "Autoview"). The
channel is not re-set at the end of the programme.
Programmes can be selected though the normal TV guide (including A-Z
listings) by "select"ing a highlighted programme. Following selection
pressing the red button forces an optional channel change when the
programme begins. Any programme shown in the TV Guide other than the
current programme can be selected - this means that only programmes up to
3 days (approximately) away can be added, as this is the usual limit of
guide information. Repeating programmes (e.g. soaps) cannot be stored to
repeat. Once a programme is finished it is deleted from the planner.
Programmes in the planner can be reviewed from the new option "0" . ("TV
Planner") in the TV Guide menu.
When stepping through upcoming channels and programmes using the channel
bar (Hit "Select" when watching live TV and step through time or channel
using the arrow keys positioned around the "Select" button) channels in
the programme guide are highlighted with a small green clock marker.
Programmes can also be added or removed from the guide using the "Select"
button.
It is reported that the automatic channel change can send a remote control
along the SCART lead to those VCRs that can support this function, but we
have not had any opportunity to test this yet.
Neither on-line help nor the Sky Information channels (998 + 999) make any
reference to these new functions - presumably Sky will wait until most or
all digiboxes are updated before customers are officially advised.
This new feature adds long-awaited and expected functionality to the Sky
Digital platform. However, the lack of repeated entries and a maximum
3-day ahead programming continue to be limitations for those wanting to
setup recordings while away on vacation. There is no chance to time-pad
entries for those occasions when the EPG is actually wrong and a programme
over-runs or is changed at the last minute. The EWPG is typically uptodate
within 24 hours, so last minute provider changes will be ignored.
Apart from other invisible software changes (bug fixes?) the only other
notable change in this software is revised graphics on menus and guides
with remarbably higher colour contrast ratios, possibly for the
hard-of-seeing.
Old 16-05-2001, 3:46 PM   #2 (permalink)
xyznicko2577
Posts: n/a
Post
Originally posted by KAO:
<STRONG>It is reported that the automatic channel change can send a remote control
setup recordings while away on vacation. .</STRONG>
The digibox will control most modern videos that accept external control, i have the early pace set up this way with a Thomson VCR and it works well.
The listings in Sky Guide have now been extended to 7 1/2 days(you can select timed events this far ahead).
There is a function called SERIES LINK in the Personal Planner which Sky appear to be working on at the moment,which allows a whole series to be recorded when selected in the Planner.
Old 16-05-2001, 7:52 PM   #3 (permalink)
Desmo's Avatar
Thanks: Gave 19, Got 140
Post
Just had a look and it's all working on mine.
Just trying it out for the first time. Should change channels at 9.00pm.
Let's just wait and see.
Desmo is offline
Old 18-05-2001, 12:05 PM   #4 (permalink)
Thanks: Gave 16, Got 14
Post
Gave it a damn good thrashing last night with my VCR. Only two complaints; 1) If (for example) movies start two hours apart on the same movie channel (say one starts at 8 and the next one at 10) and the prior movie only lasts 90 minutes you still end up recording the whole two hours, 2) It failed to recognise when one channel (G Plus) stopped transmitting at the end of its schedule and didn't power the digibox off thus causing the VCR to carry on recording.
My VCR is more of a pain (JVC 7600) because it can't use tape optimisation using the auto recording function, nor can it insert index marks nor can it auto detect that it needs to fall back to long play (obvious really, it doesn't know what the digibox is going to do). Also this function has to be set on and off by a button on the front panel of the VCR, can't do it via the remote.
It isn't a perfect solution but it is light years ahead of what I had before, tonight's viewing schedule is already set up!!!!!
[ 18-05-2001: Message edited by: mart.stokes ]
Mart S.
It's all very well in practice, but how's it going to work in theory.
mart.stokes is offline
Old 18-05-2001, 1:04 PM   #5 (permalink)
Thanks: Gave 4, Got 1
Post
I'm currently trying a forced download on my Grundig box - nothing changed when I did it about a week ago - I'll let you know if it worked (or anything changed at all) this time.
Did IQ's just drop sharply while I was away?
Gamertag - Juz
Juzminator is offline
Old 19-05-2001, 2:11 PM   #6 (permalink)
Posts: n/a
Thumbs down
I have an old MK1 Pace digibox (which I bought before Sky gave them away for free) & the relevent software hasn't yet been downloaded. A friend of mine has a Grundig box & it has the personal planner. I've tried to force a software update but nowt happened.
Cheers, Neil
Old 19-05-2001, 6:18 PM   #7 (permalink)
Mark P
Posts: n/a
Post
CHEERS GUYS, didn't know this existed, works fine on my grundig box. nice little addition to skys planner.
mark
Old 22-05-2001, 12:46 PM   #8 (permalink)
Post
Nothing changed on my Grundig after a forced download
The only thing that's different is that I can now look ahead for about 1 week as opposed to 3 days or so.
Any thoughts guys?
Gamertag - Juz
Old 22-05-2001, 12:49 PM   #9 (permalink)
Desmo's Avatar
Post
Originally posted by Juzminator:
<STRONG>Any thoughts guys?</STRONG>
Get a Pace digibox?
Desmo is offline
Old 22-05-2001, 1:41 PM   #10 (permalink)
Post
Oh haa-de-haa haa mate!
Gamertag - Juz
Old 22-05-2001, 5:32 PM   #11 (permalink)
Post
I wonder how Sky determine the order? It can't be the box because some people haven't got it yet with Paces and Grundigs, a real mystery. I presume they have a plan (then again.......).
Mart S.
Old 23-05-2001, 11:21 PM   #12 (permalink)
squid's Avatar
Post
i have mark1 pace and mine is working fine. i have been waiting for this for a long time . i remember it was one of the selling points of sky (comming soon) when i paid for my box (i got didgital as soon as it was available)
the only problem i have found is that now the information button dose not whant to show information half of the time on the banner. keeps saying synopsis not available. i have to go to the tv guide then it works .
this is quite anoying ( i like to scan the channels and and it's nice to press the info button and find out what the progrm is about
Simon p.
i have a cunning plan (a cinema in the home)
squid is offline
planner, program, sky
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Sky W/Screen & DD5.1 RichardJ Sky and Sky+ 8 21-05-2003 6:36 PM
Advice about routing sky into cinema room fatrich Computer Systems 3 19-03-2003 10:14 PM
Why is 90% of Sky TV broadcast in 4:3 !!!! Jeb Sky and Sky+ 13 19-12-2002 5:41 PM
How to access Sky Personal Planner? Chris Frost Sky and Sky+ 3 29-05-2001 10:07 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
