AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 28-05-2001, 9:27 PM   #1 (permalink)
Chris Frost's Avatar
Thanks: Gave 34, Got 77
Post How to access Sky Personal Planner?
Is this feature specific to certain STBs or common to all?
I've played with the box, watched Sky latest and even read the manual (steady on) but still no clues.
What am I doing wrong, and how do I access this feature on my Pana TU-DSB31?
Any help appreciated.
Regards
Chris Frost
Chris Frost is offline
Old 28-05-2001, 10:12 PM   #2 (permalink)
Post
Hi Chris,
Wow.. might get a chance to help you at last!
I have the Panasonic box with my Sky setup... it was running the old software until a couple of days ago... I was about to try a forced download when it got upgraded overnight!
Couldnt miss the change... the EPG has changed visually and you have an option at the bottom which says (0 - Personal Planner) or something like that... operation is easy after that...
So... I guess you could try a forced download... or just wait until it happens... others on here more knowledgable than I will be better placed to advise you on that...
Hope that helps!
Just noticed your other question on VCRs and Sats... just to let you know that Im using a Philips VCR which has a timer recording option of "Sat".. when this is used with the Panasonic and Personal planner... the Sky box turns on at the approproate time.. records the Sat... then turns everything off after.. very convienent!
Mark.
[ 28-05-2001: Message edited by: MarkT ]
VintageMark is offline
Old 28-05-2001, 10:20 PM   #3 (permalink)
Post
Chris,
I've got a Panny STB and have tried forcing the download - which it did - but still haven't got the updated software.
I guess there must be a timed rollout for some reason.
Matt
Matt Norris
Matty N is offline
Old 29-05-2001, 10:07 AM   #4 (permalink)
Post
Thanks for the help guys.
I'm trying to get a forced download to update the STB software. If this doesn't work then I guess I'll have to wait for Sky to roll out the upgrade - hope that won't be too long.
Regards
Chris Frost
access, personal, planner, sky
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Minimum package with "free" sky plus mark.carline Sky and Sky+ 13 24-07-2004 11:42 AM
Sky + planner - Strange things are happening! Lawe Sky and Sky+ 13 06-07-2004 9:30 AM
Help for a Newbie ibrox CRT Televisions 204 24-10-2003 1:54 PM
Too many connections = Bad Sky Sound ronancoll Sky and Sky+ 2 08-09-2003 10:00 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
