sky magic eye?
Old 03-01-2005, 5:45 PM   #1
ianlecompte's Avatar
4,887, Level: 16
Points: 4,887, Level: 16 Points: 4,887, Level: 16 Points: 4,887, Level: 16
Thanks: Gave 37, Got 11
sky magic eye?
i,ve just had to hide my digi box in the t.v unit,so i can fit my ps2 in.this very slightly blocks the ir signal to the box,the remote will work on it(pronto 890)but could be better.i was thinking will a sky magic eye work .as i could put the eye at the front of the unit?if it would work how would i connect it up,i know normally you would run a cable out of the 2nd out on the box to youre other t.v with the eye put in the link.do you just put the eye in the incoming ariel cable before it gets to the box?hope thismakes sense
cheers
ian
Old 03-01-2005, 7:50 PM   #2
Illustrious Member
Starburst's Avatar
40,668, Level: 49
Points: 40,668, Level: 49 Points: 40,668, Level: 49 Points: 40,668, Level: 49
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 239, Got 1,047
It will work just fine.
The only difference between your needs and the usual remote location is the length of cable between the "eye" and the digibox.
Infact you may get away with plugging the TVlink directly into the RF2 output.
Old 03-01-2005, 8:06 PM   #3
4,887, Level: 16
thanks mate,thats good news,just ordered 2 off the net for £14,i,m gonna use the 1st as prev stated,then the 2nd for the p.c,so 2 on one cable,hope it works?i.e ist direct from digi box then cable to kitchen p.c with 2nd linked there.
cheers
ian
Old 03-01-2005, 8:23 PM   #4
4,887, Level: 16
Argos have the masterplug version, a two port distribution block with two magic eyes. (£29.99) On offer at £14.99. Better as it has surge protection and can take a power supply to act as an amplifier if you need it. Maybe more useful if you want to send to various rooms.
Argos item no: 534/3906
Can confirm it will work just linked to RF2. Tried it last night.
You may be lucky and get a sky subscription pack from woolies or carphone warehouse for £10. Includes new remote, just bin the rest of the pack.
Old 03-01-2005, 8:35 PM   #5
5,241, Level: 17
Points: 5,241, Level: 17 Points: 5,241, Level: 17 Points: 5,241, Level: 17
I have 1 of these and when connected to the second tv there is no power coming to it. I connected it directly to the cable coming out from the sky box and there is power but when I try to run it through my aerial sockets it doesn't work.
Is there something special I have to do or am missing?
Do these run thru regular co-ax connections or do you need something special?
What is the purpose of the amplifier?
Old 03-01-2005, 8:43 PM   #6
4,051, Level: 15
Points: 4,051, Level: 15 Points: 4,051, Level: 15 Points: 4,051, Level: 15
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 3, Got 38
sounds like you haven't got RF2 switched on. go to SERVICES and press 4, 0, 1, SELECT and you'll reach the installers menu, go to RF OUTLETS and make sure RF2 is set to ON.
once done have a look to see if the eye works now?
HTH,
jammy
Old 03-01-2005, 8:44 PM   #7
Conspicuous Member
Crocodile's Avatar
15,114, Level: 29
Points: 15,114, Level: 29 Points: 15,114, Level: 29 Points: 15,114, Level: 29
Activity: 13.6%
Activity: 13.6% Activity: 13.6% Activity: 13.6%
Thanks: Gave 408, Got 1,147
richiecas
You need to enable the power supply to RF2 via a hidden menu on the Digibox. Instructions here.
Old 04-01-2005, 8:59 PM   #8
5,241, Level: 17
Thanks for the tips guys but as I said in my post when I connect directly to the RF2 connection on the digibox I get power but when I route it through my aerial connection in my wall to go to the second TV I get no power.
This is why I think there is some blockage on carrying power thru the aerial sockets. Has anyone come across this and what are the solutions
Old 05-01-2005, 4:54 PM   #9
7,818, Level: 21
Points: 7,818, Level: 21 Points: 7,818, Level: 21 Points: 7,818, Level: 21
Activity: 4.8%
Activity: 4.8% Activity: 4.8% Activity: 4.8%
Thanks: Gave 425, Got 577
If the SKY signal from the RF2 connection goes to your second TV via an amplifier (or Booster) then it may be that the amplifier doesn't allow a D.C. power supply to pass through it, in which case you'll need one of these:
www.tvlink.co.uk/bypass.htm
Hope this helps.
Old 05-01-2005, 5:01 PM   #10
4,887, Level: 16
Read somewhere that if your rf2 cable goes through a wall plate you may get this problem. You can apparently buy wall plates without the extra bits (whatever they are). I always find it best to have no wall plates, just terminate the cable direct to tv/freeview/vcr/sky box.
