how do i join a sky indoor arial lead
Old 19-11-2009, 5:57 PM   #1
1,343, Level: 8
Points: 1,343, Level: 8 Points: 1,343, Level: 8 Points: 1,343, Level: 8
Thanks: Gave 1, Got 0
my arial lead was not working,so i cut the connector that u plug in 2 the back of the tv off. how do i join a new one,i,ve been told i need a special adaptor/conector,to join an arial lead can anyone help
Old 19-11-2009, 8:45 PM   #2
70,171, Level: 64
Points: 70,171, Level: 64 Points: 70,171, Level: 64 Points: 70,171, Level: 64
Activity: 99.8%
Activity: 99.8% Activity: 99.8% Activity: 99.8%
Thanks: Gave 1,256, Got 3,020
Award-Showcase
What do you mean by Sky aerial?
What type of plugs did it have - did they plug in or have to be screwed in?
You can buy both types in any type quite cheap.
There's not much point in joining two cables.
Old 19-11-2009, 10:13 PM   #3
14,086, Level: 28
Points: 14,086, Level: 28 Points: 14,086, Level: 28 Points: 14,086, Level: 28
Activity: 43.6%
Activity: 43.6% Activity: 43.6% Activity: 43.6%
Thanks: Gave 84, Got 576
Originally Posted by sylv6 View Post
...so i cut the connector that u plug in 2 the back of the tv off.
This is a Sky question?
Old 19-11-2009, 10:47 PM   #4
1,343, Level: 8
hi i mean the arial lead that u plug in2 the back of the tv.silver colour with small prong in the middle.i want to attach a new one to the old lead..do i need a special connecter . i,ve tried tape and those joining blocks,but they don,t work,thanks
Old 20-11-2009, 7:30 AM   #5
15,354, Level: 29
Points: 15,354, Level: 29 Points: 15,354, Level: 29 Points: 15,354, Level: 29
Thanks: Gave 18, Got 1,045
You mean a standard male coax plug as per the attached illustration.
Instructions on how to fit one here
YouTube - How to fit a UK TV plug to coaxial cable
sylv6 (20-11-2009)
Old 20-11-2009, 10:21 AM   #6
1,343, Level: 8
hi
thanks 4 ur help..i shall have a go a t that later.
Old 20-11-2009, 8:23 PM   #7
70,171, Level: 64
Activity: 99.8%
Award-Showcase
Please reply to the question in post #3 - this doesn't sound like a Sky-related question and if it isn't then it's in the wrong forum.
What is the other end of this cable plugged into, and why can't you just get a new ready-made cable without joining anything?
Old 20-11-2009, 8:47 PM   #8
1,343, Level: 8
hi thanks 4 ur message i need the silver plug as shown in fernandez thumbnail...i am going 2 get one 2mor...hopefully that should solve the problem.and no i don,t need to join the lead now...i will let u now if i succeed..thanks
Old 20-11-2009, 10:51 PM   #9
70,171, Level: 64
Activity: 99.8%
Award-Showcase
That's OK and do let us know how you get on, but please do let me know if this is anything to do with Sky.
If it isn't I can't leave the thread here and will have to move it.
Logiciel.
Old 20-11-2009, 11:58 PM   #10
1,343, Level: 8
the lead runs from my sky box in lounge to my bedroom..
Old 21-11-2009, 5:21 PM   #11
1,343, Level: 8
hi thanks 4 ur help. i bought 2 deluxe male coax plugs 2day...followed the video and it works fine...i also wired up a lead to my spare room and used a splitter and now have sky in my spare room as well.ur help has been invaluble..thanks a lot..sylv6
Old 21-11-2009, 5:35 PM   #12
70,171, Level: 64
Activity: 99.8%
Award-Showcase
That's OK and I know what it is now!
