panasonic sky box
Old 19-11-2009, 4:54 PM   #1
2,541, Level: 11
Points: 2,541, Level: 11 Points: 2,541, Level: 11 Points: 2,541, Level: 11
Thanks: Gave 9, Got 13
panasonic sky box
I have recently noticed a "wobbly" picture effect on my Toshiba 20wlt56 lcd tv.It's like a slight wave going down the screen. This is probably a fault of the tv but could the sky box cause this sort of effect if it were faulty? My other set connected to the same dish is ok
Old 19-11-2009, 5:09 PM   #2
6,042, Level: 18
Points: 6,042, Level: 18 Points: 6,042, Level: 18 Points: 6,042, Level: 18
Activity: 5.3%
Activity: 5.3% Activity: 5.3% Activity: 5.3%
Thanks: Gave 10, Got 290
It is theoretically possible. But unlikely. Try playing a DVD through the TV.
Old 19-11-2009, 5:22 PM   #3
28,180, Level: 40
Points: 28,180, Level: 40 Points: 28,180, Level: 40 Points: 28,180, Level: 40
Activity: 99.4%
Activity: 99.4% Activity: 99.4% Activity: 99.4%
Thanks: Gave 39, Got 2,262
If you are using a hdmi lead try another or moving it it's not unknown for some to interefere with tv's
Old 19-11-2009, 8:40 PM   #4
2,541, Level: 11
It's connected by a scart lead and each end is secure
