Originally Posted by the_sanguine
So it I cancelled, bought a SH HD box, I could then get the free HD channels? Would I need to get the card paired to the box? |
The FTA channels do not require a card at all - they are FreeToAir
However, without a card BBC1 may default to London, ITV1 to West Midlands, FIVE will not appear on the EPG and will need to tuned in manually and be accessed through 'Other Channels'.
Whether you would get ITV-HD depends on the box and which EPG it has.
With a card you would get the correct BBC/ITV regions, FIVE will be on the EPG at 105, you'd also get Sky3 and Channel4HD but any enabled card should be OK
