Sky+ Codes for a LG needed please
Old 17-12-2008, 4:36 PM   #1
Thanks: Gave 3, Got 2
I have a LG 50" Plasma tv (Model - LG 50 PT8) and cannot set up the Sky+ remote to operate the tv.
Has anyone any codes or ideas . Thanks
Old 17-12-2008, 8:43 PM   #2
Thanks: Gave 1, Got 31
Re: Sky+ Codes for a LG needed please
try 0056 works on most lgs
ALB10N (16-07-2009), wormvortex (12-01-2010)
Old 18-12-2008, 2:30 AM   #3
Thanks: Gave 1, Got 1
Some codes available Here
Old 18-12-2008, 6:37 PM   #4
Tried those Smiler & Brad - No luck yet!
Old 18-12-2008, 6:51 PM   #5
Limited Member
fernandez's Avatar
Thanks: Gave 18, Got 1,046
Loadsa codes here
Sky Codes 2
Check Goldstar/Lucky Goldstar (LG)
What revision number is your Sky remote?
Old 19-12-2008, 2:32 PM   #6
My Remotes a Rev.6 Version
Old 19-12-2008, 2:56 PM   #7
Limited Member
fernandez's Avatar
This note from LG is taken from the Satcure website
"Note: The LG codes that Sky have provided us to work with our newer television sets are;
0037, 0056, 0060, 0065, 0080, 0081, 0125, 0137, 0178, 0191, 0204, 0244, 0245, 0275, 0318,
0389, 0391, 0398, 0405, 0459, 0502, 0742, 1146, 1367. We also have some older codes;
206, 037, 060, 065, 080, 137, 191, 244, 245, 275, 318, 389, 391, 398, 405, 459, 502.
The codes are stored in a database of the Sky remote. If the above codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes. Best regards, LG Electronics.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851"
Have you tried Sky CS, Sky Interactive (Press [Interactive], Sky Active > Help Centre > Set Up My Remote), LG or can you borrow a Rev8 version to see if it works
Old 20-12-2008, 2:10 PM   #8
None of these codes work.
Is there such a thing as a autosearch facility on the remote/
Old 20-12-2008, 2:20 PM   #9
Limited Member
fernandez's Avatar
You could try this
1. Press TV
2. Press SELECT and the red button simultaneously until the LED light flashes twice
3. Then keep pressing the TV and Standby buttons one after the other (not at same time) until the TV switches off, then press SELECT to store the code, the LED should flash twice to confirm this
It may/may not work.
As I suggested earlier contact Sky and/or LG but be prepared to accept that there may not be a code for your TV - the remote is not guaranteed to work all devices
Old 21-12-2008, 3:49 PM   #10
Thanks: Gave 1, Got 10
You will probably need a rev 8 or newer
Old 21-12-2008, 5:21 PM   #11
Limited Member
fernandez's Avatar
AFAIK Rev 8 is the latest version.
I've already suggested this but from the looks of things (see the note from LG above) a code may not(?) be available
Old 23-12-2008, 9:43 AM   #12
Thanks Everybody but extra thanks to Fernandez for your help and advice.
Problem sorted.
I bought a Rev 8 remote and used LG code 0056 and SUCCESS.
Thanks everyone again and Merry X-Mas
Old 25-12-2008, 3:09 AM   #13
Thanks: Gave 67, Got 20
Sorry to thread hijack, but I thought better to ask here first, before starting a new topic.
I'm having the same problem finding a code for my LG.
My question is, how do I know if my remote is Rev 8 or 6 or earlier? Until looking for this code, I'd assumed all the remotes were the same.
Thanks.
Old 25-12-2008, 7:54 AM   #14
Limited Member
fernandez's Avatar
Originally Posted by Lyceum View Post
... how do I know if my remote is Rev 8 or 6 or earlier?
The number is on a sticker inside the battery compartment
Old 29-12-2008, 11:43 AM   #15
iantomos
Posts: n/a
I have a 37" LG lcd, which is great, but could not get the sky+ remote to work the tv. All you need to do (it does work as i,ve just set mine up ) is buy a new sky+HD remote (£10 on ebay) and use the code 0056 in the set up process (as per sky booklet) to get it to operate the tv. At this point the remote wont operate the sky+ box. To get it to work, press TV on the sky+HD remote, then select and i together (led flashes twice) and then press 1. Hey presto,result!!
