Gigaair 2727 Video Sender
Old 04-03-2007, 7:20 PM   #1
Thanks: Gave 1, Got 0
I bought a Gigaair 2727 today (£40) to feed a standard sky ditigal signal from a bedroom to the dining room directly beneath. The picture wasn't fuzzy but had bad interference (horizontal distortion and a regular cracking sound). No amount of fiddling with the antenna improved it.
I've heard these devices can conflict with wireless networks so I switched off my router which didn't make much difference.
So I took it back to Comet.
Has anyone much experience of these? I work near a Maplin so thought I'd try picking up a Digisender but don't want to spend a fortune.
If the Gigaair didn't work, are there others on the market which give out a stronger signal? or is it not worth it?
Simon
Old 23-04-2007, 3:56 PM   #2
Jonnywishbone's Avatar
Thanks: Gave 24, Got 1
Re: Gigaair 2727 Video Sender
Just bought the same device from maplins. Mine didn't work whatsoever so am going to send it back. This is the second such device I have tried and have come to the conclusion that you can't have it all! (homehub,dect phones etc)
Back to the drawing board, unless someone releases these devices on a different frequency to wifi then wired is the only way forward in my opinion. That's if the wife allows me to start drilling holes that is!
Old 23-04-2007, 5:41 PM   #3
Thanks: Gave 13, Got 372
They are available with a (much) higher frequency.
Old 24-07-2007, 8:09 AM   #4
lukeyluke
Posts: n/a
Hello.
I've just bought a GigaAir 2727, and I can get clear sound in the bedroom but no picture.
Can anyone suggest what I'm doing wrong???
If I can't find a solution I think I'll have to take it back and buy another model...
Rgrds
Luke
Old 05-10-2007, 10:45 AM   #5
ijmunro69
Posts: n/a
SamRadford, can you suggest a unit with a (much) higher frequency. I live next to a hotel which is a wireless nightmare for me and so doesn't work. All help appreciated.
Old 09-10-2007, 2:41 PM   #6
Thanks: Gave 2, Got 0
I have just bought a Thomson AV sender from Comet for £30. It has a number of different channels to try and avoid clashing with any other equipment using the same frequency. One of the channels seems to work fine and it is sat next to a Wifi device and we have 4 DECT phones.
Old 09-10-2007, 8:27 PM   #7
JayCee's Avatar
Thanks: Gave 253, Got 1,396
Scart plug at either end not plugged in fully?
Old 17-10-2007, 9:22 PM   #8
Thanks: Gave 16, Got 16
Hiya,
sadly all of these senders work in the 2.4Ghz bandwidth, the same as ALL wireless networking gear, and quite a few phones, oh and also microwaves (they creep into this range).
I've just tried two different types of sender and both such, i do live in the middle of london with lots of wireless noise, which is probably the main problem - also 2.4Ghz doesnt 'do' corners, it either passes straight through or bounces, thats why wireless tends to be bad in old houses.
You can get 5.8Ghz (i think) devices from the states, they will probably be brilliant...BUT they are illegal in the UK because that licence is not for public usage.
Old 31-08-2009, 6:53 AM   #9
I just wanted to say that i brought a Gigaair about 2 years ago and I have not had much problems with it. Yes when you use the micrwave or the xbow you get interference but apart from that its fine. If you hear any fuzzy noise coming from the telly that you transmitting to you need to adjust the other box and play around with it a bit like you would a normal arieal. When it set DON'T TOUCH IT even a slight movement can knock it out of whack. It works well Sky TV in my bedroom and the actually box is in the living room so it does what it says on the box it has saved me loads of money cos i have not had to invest in a multi room thing from Sky.
