Originally Posted by GMT im possitive im not or was ever called techgit.
if they werent wired up to anything then why can i charge my ipod through my sky+? |
I said the majority of boxes - not all boxes. Some are wired up, that's how people can charge their ipods, some aren't. On Digital Spy there's a discussion going on about which manufacturers have connected the USB port to the Sky+ motherboard and which ones didn't bother, under instruction from Sky. Supposedly the initial spec said that any company who wanted to start manufacturing Sky+ boxes had to build at least one USB port in (from V3 onwards), so all future manufacturers designed the box front ends or back ends to hold the USB port, then Sky backtracked and said that they weren't necessary in the near future, at which point one of the manufacturers still went ahead with keeping the ports in the box casing, as they had already been designed, but didn't bother wiring the port to anything on the motherboard. One of the other manufacturers did connect the USB port to the motherboard, which is why it can charge your ipod. But it can't do anything else - maybe you could plug one of those PC coffee cup warmers into it - there was a novelty USB coffee cup warmer that came out a couple of years ago, basically a little mat that you stood your cup on, and it generated enough heat to keep your coffee warm by drawing on energy from the USB port in your computer.
Apologies for suggesting you were techgit, come back to haunt us all once more...
