Anytime + not working
Old 29-03-2012, 7:57 PM   #1
Thanks: Gave 3, Got 2
Just activated this using bt ISP. My router is a netgear wndr3700 and it will not work. Just says service connection fail. Spent 45mins on the help line and they could not get it to work. Rebooted, reset everything. Normally connected using homeplugs but also tried a direct connection. Still no change. Any ideas please.
Old 29-03-2012, 9:53 PM   #2
Thanks: Gave 0, Got 19
now works for me
i had this problem but i searched on here and saw a this tip that worked. in the EPG go to options and turn broadband connection on.
Old 30-03-2012, 1:10 PM   #3
Done that. It connected to the router because I have an IP address and I can see it from the router. It just will not work.
Old 30-03-2012, 7:40 PM   #4
Thanks: Gave 1,854, Got 4,215
Do you mean that you were speaking to a Sky agent about it?
If so what happened - did they say they wouldn't do anything about it?
Old 30-03-2012, 9:41 PM   #5
Yes. He went through everything on his system and nothing worked. After about 45mins he gave up. His only suggestion was to try a different router. He said it was early days and they were still learning.
Old 30-03-2012, 11:12 PM   #6
They're pathetic. I'd put it in writing on the complaints form at MySky.
Old 30-03-2012, 11:42 PM   #7
D-an-W's Avatar
Thanks: Gave 228, Got 152
Does the Router give any information on the connected devices, can you "see" the Sky box is talking to it if you know what I mean...?
Old 31-03-2012, 3:39 AM   #8
Miss Chief's Avatar
Thanks: Gave 274, Got 798
In the network screen, what does the local and service connections say? I'm guessing Local=OK and Service=fail?
If they both say OK then it's something to do with the subscription or the viewing card.
Old 31-03-2012, 7:03 PM   #9
Hi all,
The router can see the sky box. Gives it an ip address and I can see the connection. Its service fail. However and here's the strange thing, i've just put my old BT homehub 2 back into service and it connects ok. So it's something to do with my router and or modem -dreytek vigor 120
Old 31-03-2012, 8:01 PM   #10
Further to my last update I have just downloaded the latest firmware to my model and it's working. Do not ask me why
