3.5 million visitors each month
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky HD
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Wanted : Single 14Mbps Homeplug uzi123 Gaming Classified Adverts 2 25-04-2009 5:21 PM
Old 23-04-2009, 5:38 PM   #1 (permalink)
Single Feed Mode! (If you live in a flat and have lost your picture, try this...)
Hi all,
I just registered on the forum because I wanted to ask why I had no picture since this morning (I received the new HD menu system overnight). However I've just found out how to fix it, so I thought I'd still post on the forum and share it with you in case anyone else has same problem...
By the way, I just spent 25 minutes on the phone to Sky (in India) and the guy did not mention this at all... which I find unbelievable. All he did was tell me to switch off the LNB and switch it back on again... useless!
Anyway, if you live in a flat then you've probably only got a 'single feed' - that is, one wire plugged-in to the "Dish Input 1" at the back of the box, and nothing plugged-in to "Dish Input 2".
If you are in that scenario and you are getting a "No Satellite Signal Received (28)" error, do the following (assuming you have the new menu system)...
* Make sure your sky cable is plugged into "Dish Input 1"
* Press Services on your remote
* Press Right-Arrow and highlight "Settings"
* Press Down-Arrow and highlight "Picture"
* Press 0, 1, Select
* The "Setup" tab will now appear
* Scroll down and select the "Single Feed Mode" option
* Press the Right-Arrow and change it from 'OFF' to 'ON'
* Press the Green Button to Save the settings
* A 'Caution' message will appear... Press 'Select'
* Your system will now switch-off/reboot
* Leave it for a couple of minutes
* Press the Sky button to bring it back to life
* Hey-presto, you can see the picture again!
... and screw-you Sky Customer Services for trying to charge me £65 for an engineer to come out and 'fix' my not broken HD Box!
JoeFX is offline   Reply With Quote
paulgjohnston (23-04-2009)
Old 23-04-2009, 5:49 PM   #2 (permalink)
kenedin's Avatar
Thanks: Gave 15, Got 216
Re: Single Feed Mode! (If you live in a flat and have lost your picture, try this...)
Thanks for that. You'll also find the instructions on the Sky Help Centre website:
Setting Up Your Sky+HD Box If You Live In A Flat.
Panasonic TH-42PX600B, Panasonic Home Theatre SA-HT855, Thomson 3007 Sky+HD, BT Broadband, comfy couch
kenedin is offline   Reply With Quote
Old 23-04-2009, 5:56 PM   #3 (permalink)
paulgjohnston's Avatar
Thanks: Gave 114, Got 24
Many thanks for this!
paulgjohnston is offline   Reply With Quote
Old 04-05-2009, 12:34 PM   #4 (permalink)
mooperman's Avatar
Thanks: Gave 813, Got 248
is there a single feed mode for the current menu system does anyone know?
Xbox 360 Tag - Original Moo ------- PSN Tag - Original-Moo
mooperman is offline   Reply With Quote
Old 04-05-2009, 12:44 PM   #5 (permalink)
kenedin's Avatar
There isn't a single feed mode, as such, but have a read. It's as good as any.
Sky+ With Single Satellite Connection.
mooperman (04-05-2009)
Old 04-05-2009, 12:51 PM   #6 (permalink)
mooperman's Avatar
Thanks man,
so reading that i basically set it to record any channel daily which will fail as it tries to use the 2nd feed and then anything i wanna record whilst im out i just set as normal and it will use the 1st feed?
ta
M
Old 04-05-2009, 1:08 PM   #7 (permalink)
kenedin's Avatar
That's right. Remember to periodically delete all those 'failed' recordings in the hidden menu in your current Sky+ Planner ( use the >Options & yellow (?) Recorded button at the foot of the page to show these ).
I'm on the new EPG now, but I think that's correct ( from memory ).
Old 04-05-2009, 4:16 PM   #8 (permalink)
mooperman's Avatar
yep, bang on the money, set a couple of recordings when i went out and it worked a treat..
Now all ive gotta do is wait for the new EPG so i can set single line mode...
cheers
Mark
Old 04-05-2009, 4:20 PM   #9 (permalink)
Thanks: Gave 8, Got 125
Nice one mate, we have moved from our old house into a city center flat and use a communal dish and have had this problem a lot recently.
Pioneer Kuro LX5090, Xbox 360 x2, Harmon Kardon AVR255, Sky HD, AppleTV (hacked) x2, WDTV Live, Kef Q9 Centre, Kef Q3 Fronts, Kef Q1 Surrounds, SVS PB10-ISD Sub x2, Apple Macbook Pro 15", 2 x Lacie Network Space 1Tb, 4 x Lacie 1Tb
Sy1441 is offline   Reply With Quote
feed, flat, live, lost, mode, picture, single
