3.5 million visitors each month
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky HD
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Sony BDP-S350 Firmware Upgrade Help unfitgit Blu-ray Players 21 09-06-2009 9:57 AM
New Onkyo 606 hum problem - fault? Andrewid Onkyo Owners' Forum 21 09-02-2009 6:40 PM
Pioneer BDP-51FD region problem samuelho12 Blu-ray Players 5 08-02-2009 8:11 AM
Problem with Samsung 4 Series 32" LCD a Capibara LCD Televisions 2 12-01-2009 5:50 AM
NAS Hard drive Woodsie Networking and NAS 4 12-01-2009 3:50 AM
Old 12-01-2009, 8:56 AM   #1 (permalink)
500gb hard disk upgrade problem
Hi, I have searched the forums but cant find any detail. I upgraded the hard disk on my Thomson HD box to a 500gb western digital wd500aaks. I just swapped the disk and didnt copy across any programmes as I understood that the HD box would format the new disk. When I powered my box back up it waited about 1 min and then the drive started spinning. It sounded like it was starting and stopping for about two minutes but was pretty loud and clunky. After that it stopped but the sky box wouldnt power on.
It then started the cycle again for the same time and when it stopped the box still wouldnt power on.
I tried rebooting again and the same thing kept happening. Eventually I gave up and just put the original disk back in which worked fine.
What I want to know is do I have a problem with the disk (which was brand new from Amazon) in which case I can send it back for a swap, or is it something I have done wrong, e.g. not formatting or preparing the disk properly?
Any help would be appreciated.
Ben
Ben9040 is offline   Reply With Quote
Old 12-01-2009, 10:01 AM   #2 (permalink)
chic's Avatar
Thanks: Gave 99, Got 705
Re: 500gb hard disk upgrade problem
Ben
sounds like a duff disc to me, also some discs have problem working with sky hd, do a search and choose a disc drive that someone has got to work with sky hd. Also why not go for a bigger disc such as a 1 terabit drive as the 500gig one isnt giving you that much extra space and using copy + and an extranla caddy is very easy to do.
Samsung UE46B7000 ,Optoma hd70,,SVS SB12 Plus ,Onkyo 876,Mordaunt Short Avant 906i, Mordaunt Short Avant 905,Mordaunt Short Avant 903i ,Mordaunt Short 902i,Skyhd,PS3,XBOX360,HE-1, E-30,XBOX360,Oppo BDP-83,Samsung BDP1500,Harmony one remote
chic is offline   Reply With Quote
Old 12-01-2009, 10:41 AM   #3 (permalink)
Thanks: Gave 17, Got 8
If you have PC connect it in and download tools which can check it for you. See WD's website support section. If they pass then there is something else which is at fault.
Fulltopuk
Fulltopuk is offline   Reply With Quote
Old 12-01-2009, 10:51 AM   #4 (permalink)
Thanks: Gave 1, Got 20
Using Copy+ you can just format the drive for use that might be worth a try.
digigriffin is offline   Reply With Quote
Old 12-01-2009, 11:58 AM   #5 (permalink)
Thanks: Gave 4, Got 30
Would agree about the formatting, should be as "basic disk" not dynamic, which it may have come from manufacturer as. See here
ABC1 is offline   Reply With Quote
Old 12-01-2009, 1:22 PM   #6 (permalink)
thanks for the help guys, i will try and format the disk and give it another go.
Old 12-01-2009, 2:43 PM   #7 (permalink)
Thanks: Gave 300, Got 151
WD 500 aaks should work without any problems in a Thomson box.Mine does and imo lots of others also.This has always been one of the 500gb drives of choice.
Check your connections ......loose Sata .....easily done.
BrianPK is offline   Reply With Quote
Old 12-01-2009, 3:47 PM   #8 (permalink)
yeah thats why I got the WD one so it would be no hassle! I checked and double checked the connections and the old one went straight back in no problem so dont think its that. I will try and see if it is a formatting problem by adding the disk to my PC but havent got an external caddy and dont really want to spend £15 on one to just find out that it is the disk that is broken and then never use the caddy again!
500gb, disk, hard, problem, upgrade
