28-12-2008, 7:34 PM
#16 (permalink)
Re: HD XMAS Test card
thanks for that, I'll give it a go tonight.
28-12-2008, 11:17 PM
#17 (permalink)
Thanks: Gave 3, Got 33
The BBC have been showing there new HD test card during the Preview hours, details can be found here:-
BBC Internet Blog
Be warned the instructions are pretty in depth!
Tony
Panasonic TX-P50G10B, Panasonic TH-37PE30B, Samsung BD-P1500, SKY+ HD, SKY+, Xbox360 Elite, Xbox360 Premium, Onkyo SR-605, Onkyo DS-A3 Dock, Jamo A102 HCS5
29-12-2008, 7:41 AM
#18 (permalink)
Thanks: Gave 21, Got 39
Some DVD's have a THX optimizer on the main menu......its far better than the Sky effort!
Terminator 2 has it.....and EVERYONE has a least one copy of that movie don't they?.....
29-12-2008, 7:47 AM
#19 (permalink)
Conspicuous Member
Location: Real guitars don't have strings, they have 5 coloured buttons.
Thanks: Gave 425, Got 636
The Bourne Conspiracy game has the THX, so you can optimise use that, and it should be in HD seeing as the game is 720p.
Originally Posted by r2001uk
I thought DieEasySteave was called DiseasySteve for a moment, I almost had to hit the leper alarm!
Classic
29-12-2008, 9:55 AM
#20 (permalink)
Thanks: Gave 26, Got 27
Hmm this isn't on my Anytime menu. Gutted.
29-12-2008, 9:57 AM
#21 (permalink)
Thanks: Gave 36, Got 83
The problem with that is that many displays have separate settings for each input and if you've had your screen calibrated each input has to be treated separately. But where all inputs share the same settings it's a good suggestion although I still think you glean more info from the test card.
I do have T2 but still like to see the BBC Test Card F. I guess I'm just old-fashioned.
ISF Calibrated Panasonic TH42PH9, Denon A10-SE , Arcam DV79 , Denon DTR2000 DAT, Pace Sky HD 1080i mode, B&W CM4 / CMC / 600.3, JS Technology RGB-YUV converter, QED AV41 Sqart, Van Damme VGA cable, QED Qunex HDMI, Marantz TS5000 remote.
29-12-2008, 7:36 PM
#22 (permalink)
Thanks: Gave 87, Got 161
The problem with most displays is the contrast level, but both the Sky and BBC HD test cards just rely on setting it by eye "whatever looks right". That really doesn't help much. Neither does setting the colour according to "personal taste".
Both cards are useful when it comes to brightness, but the BBC's frequency patterns are compromised by the 1440 broadcast resolution.
Other than an ISF calibration, a sensor and some software might be a better alternative for those who have invested a proportionate amount in their displays. Something like a Spyder (useful for computer monitors too) and CalMAN or even the freeware ColorHCFR.
29-12-2008, 9:41 PM
#23 (permalink)
Thanks: Gave 22, Got 6
well i followed your 'instructions' with the Sky HD card & when i had finished my picture looked cr*p !
Ive got a calibration blue ray dvd on order, will have a go with that. If it still looks rubbish, i will get it set up professionally cos im useless
ps, its a Samsung 8 series lcd.
02-01-2009, 7:57 AM
#24 (permalink)
Thanks: Gave 0, Got 2
I never got this on my anytime, would someone please supply a picture of it? I know its not as good as testcard f but I would like it for my computer desktop to use next year! Thanks.
02-01-2009, 8:48 AM
#25 (permalink)
Just rechecked my 42" Panny with the improved THX optimizer on T2 Blu Ray.
I have the US version of T2, not sure if the UK version has the optimizer on though.
02-01-2009, 9:45 AM
#26 (permalink)
This isn't the BBC Test Card but it should be just as useful.
http://feldoncentral.2150.com/HDNet/...Pattern_01.jpg
02-01-2009, 10:25 AM
#27 (permalink)
Location: Down at the bottom of the garden, amongst the birds and the bees...
Thanks: Gave 72, Got 187
A couple of interesting links in here, thanks. I wonder if I could ask a question too as this seems a good place for it.
I have an EyeOne Display 2 and used to use my laptop to play blurays on my HDTV. I used the supplied software and the EyeOne and got a great result with really good blacks and nice accurate but vivid colour.
I now use a Panasonic BD30 connected up to the tv and therefore it is not "properly" calibrated. I find that blacks are not as dark as they were via the laptop and regular sky via scart has better contrast than the bluray player. I find it quite noticeable when watching a letterboxed film in the dark as the black bars are not as black as the bezel and I know they looked better via the laptop.
So I was wondering exactly what the software mentioned on in this thread will do - they mention support for my EyeOne.
Do I hook the EyeOne up to the laptop and then measure from the tv and this software tells me what to change on the tv or is it the same as what I had done before?
I hope that makes sense. I basically want to improve the contrast and accurately profile the tv for all sources.
I eventually plan to have a HTPC under the tv which will accept my satellite feed and play bluray etc and so that will be calibrated with the eyeone and software. I'd like to know if there's anything I could do to improve the result for other sources though, especially my BD30.
Panasonic TX-P50V10  , Denon 2309, Monitor Audio Bronze, Denon DVD-1800BD, SKY+HD, 360 Elite, Astro A40s, Harmony One, QED HDMI, Silver Anniversary XT, Soundstyle ST310 stand, Sony AR51SU Laptop, Canon 20D DSLR, Panasonic LX3 "compact", Sony Xperia X1
02-01-2009, 11:15 AM
#28 (permalink)
Thanks: Gave 141, Got 769
Mudstuff,
Have a read of the link in the first post of this thread. It is a well written and clear guide to greyscale calibration, why to do it, how to do it, etc. Its based on using the HCFR software and does support eyeone (not sure if thats a 2 or not). Interesting read anyway even if you don't/can't calibrate your greyscale.
02-01-2009, 12:26 PM
#29 (permalink)
Exactly what I was after thanks. I wondered if there was a way to improve the display quality with current kit. So I just need the DVE Bluray along with my EyeOne and laptop? Thanks.
I've scanned through some of the article, I assume it goes into good detail? I don't think there's much I can change unless I go into the service menu so hopefully it explains what all those settings are for...
