Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky HD
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
samsung plasma hd query mgfredy Plasma Televisions 5 24-09-2008 4:47 PM
Help with new Samsung LE40A436T and Sky + code bez7293 Sky and Sky+ 1 23-07-2008 1:24 PM
Samsung LE40A436T - Where can i find reviews? RamboULW LCD Televisions 0 09-06-2008 10:42 PM
Samsung LE27S71B Query forrestgump LCD Televisions 0 16-05-2007 3:04 PM
Query about the Samsung E700. PoochJD Samsung Mobile Phone Discussions 1 16-06-2004 11:19 AM
Old 02-12-2008, 10:25 PM   #1 (permalink)
Thanks: Gave 20, Got 23
Another Sky HD query - with Samsung LE40A436T
I seem to have a headache with the combo of the Sky HD box and the LE40A456T.
The TV is connected to HDMI2, but when I switch on the TV the Sky box doesn't recognise any of the Sky remotes commands.
The TV stays on the last channel watched (usually Catroon Network from the kids!).
What I have to do is grab the Samsung's remote and scroll through the AV connections back to HDMI 2 and then when I hit the 'tv guide' button on the sky remote it all works.
Completely frustrating - is there a setting I am missing on either the HD box or the TV?
I need this fixed as this HD box will be the source of my HD distribution through the house, so it needs to work - I don't fancy having to wander downstairs to sort out the box when I want to watch TV in bed!!
Per
Per156GTA is offline   Reply With Quote
Old 02-12-2008, 11:05 PM   #2 (permalink)
loz
Thanks: Gave 259, Got 757
Re: Another Sky HD query - with Samsung LE40A436T
have you accurately described how it is set up, and the behaviour you are experiencing? Because it doesn't sound quite right.
What tv input your sky box is connected to should make no difference to how the sky remote works. The sky remote should change the channels on the sky box, even if it wasn't connected to anything...
It is simply that your kids have pressed the tv button on the sky remote, so they could turn the tv off, and you know have to hit the sky button to get it back to controlling the box instead of the tv?
Also, remember that few tvs will automatically select the sky iHD input when connected via HDMI. You're might to have to do that manually by selecting the input channel each time - unless your tv remembers last input used (it sounds from the description like it may), or there is some other setup that enables this to happen.
loz is offline   Reply With Quote
Old 03-12-2008, 1:30 AM   #3 (permalink)
Thanks: Gave 44, Got 576
Does that actually mean the Sky receiver is connected to the TV's HDMI2 socket?
If the receiver does not respond to its remote's commands then the problem is obviously nothing to do with the TV, but might be just because the remote has been left in the option to control the TV rather than the receiver.
My opinions expressed here do not represent those of AV Forums or associated websites - Tosh 42X-3030DB, Thomson 607120Q Sky+ HD, Technomate 6800 HD, Passion+ HD, Onkyo TX-SR607, Bush BluRay, Tosh HD-EP30 HD-DVD, P-B EHR-2080 HDD/DVD Rec, Tosh SD-23VB DVD/VHS, Thomson DTI2300, Harmony 525-One-900-1100
logiciel is offline   Reply With Quote
Old 03-12-2008, 8:42 PM   #4 (permalink)
yes, the HDMi lead runs frm the HD box to HDMI2 on the TV.
Where do I find the option mode to control the TV in the HD remote? I have looked but can't seem to find it!
Per
Old 03-12-2008, 8:46 PM   #5 (permalink)
Yes, pretty much so - I did think that chosing HDMI 1 or 2 wouldn't make a difference, which is why I was wondering if the issue was with the HD box or Sky remote!
Kids don't set the TV to standby, and I always switch off the TV on the button - having said that however, the button is always lit up red, so it may be on standby!! Something for me to look at in the manual.
Per
Old 04-12-2008, 8:03 PM   #6 (permalink)
It may well be that teh headache comes because the TV is in standby. The manual tells you how to set to standby, but not how to switch it off - any ideas? If I just switch off mnually rather than with remote, it goes back to standby, so that doesn't reset it!
Any thoughts?
Per
Edit - ignore this - it seems that Samsung does not have a full switch off facility - its always on standby - guess its a Sky issue then!
Old 04-12-2008, 9:10 PM   #7 (permalink)
loz
you just press the TV button on the sky remote - though you would have to set up the TV code for your TV first.
query, samsung, sky
