3.5 million visitors each month
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky HD
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Pace PVR3 Screeches on Standby Crocodile Sky and Sky+ 1 18-08-2008 4:36 PM
SKY+ Pace TDS470N goes into standby overnight Dai O Sky and Sky+ 2 27-04-2008 12:03 PM
Pace Sky Box stuck in standby barachello2000 Sky and Sky+ 4 17-10-2006 8:54 AM
My Pace DS810 Free-to-air HD RX won't come out of standby - HELP! ajb2603 Sky HD 0 24-06-2006 4:29 PM
Pace digi box locks up ???? marcatkins Satellite TV 3 21-02-2002 10:59 PM
Old 13-11-2008, 2:09 PM   #1 (permalink)
Pace HD box locks up in standby
I bought a new Pace HD box last week, updated to latest firmware immediately and all registered with Sky etc. Normally works fine, but if I either let the box automatically go into standby, or manually put it into standby myself, then by first thing the following morning the box has locked up. Only a power cycle will cure the problem. Has missed several recordings as a result. Has anyone else experienced this?
therobveiller is offline   Reply With Quote
Old 13-11-2008, 3:20 PM   #2 (permalink)
kenedin's Avatar
Thanks: Gave 15, Got 217
Re: Pace HD box locks up in standby
Is this a box supplied by Sky? If so, it's faulty, and is probably overheating throughout the night in standby. Why? Not sure about this, but it could the fans are inactive on standby and the box has turned itself off, or maybe a component eg the LNB is overheating ( it has happened before ) .
Is the box hot to the touch first thing in the morning? More so than when in use? Have you spoken to Sky about this?
Try a test . Switch off the LNB Power Supply & 22KHz Command tonight when you retire, and see if it fires up OK tomorrow. ( Services>4>01 Select ).
A long shot, I know, but it's really anyone's guess what's wrong. Anyone else got any ideas??? Hard drive connections? Internal cable??
Panasonic TH-42PX600B, Panasonic Home Theatre SA-HT855, Thomson 3007 Sky+HD, BT Broadband, comfy couch
kenedin is offline   Reply With Quote
Old 14-11-2008, 1:13 PM   #3 (permalink)
[FONT=Verdana]Hi, as I say it's a bought box (not Sky supplied). I found in another forum that several people had "wiring faults" on the Pace boxes, when what I think is really meant is a dry-joint.[/FONT]
[FONT=Verdana]I have discovered that if you press even lightly on the base of the box, it locks up even with the system on, so clearly a faulty box and I have been on to the supplier about this.[/FONT]
[FONT=Verdana]It looks at though the standby was partially a red herring. I think that despite being in a well ventilated area (on a hi-fi shelf, not enclosed in any way) that the temperature difference between the unit on and off is enough to make the dry-join expand and contract and lock up the box. If left on (auto-standby disabled) and I don't move/knock the box when turning off the TV, all is fine. The supplier has agreed to replace the box, but I thought the extra info might be of some use to anyone else.[/FONT]
[FONT=Verdana] [/FONT]
[FONT=Verdana]Rob[/FONT]
Old 14-11-2008, 1:31 PM   #4 (permalink)
kenedin's Avatar
Better luck with the next one!!
box, locks, pace, standby
