Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky HD
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Lip Sync with Sky HD - Optical and with Scart ramyad Sky HD 22 20-09-2008 5:14 PM
Audio sync constantly drifting - PS3 with optical Simon Young PS3 Media & Streaming 4 28-02-2008 11:04 PM
Slow boot with HDMI and Optical? Otaku Punk Xbox 360 6 11-01-2008 3:37 PM
LYP Sync on Optical out... tvdavid Sky HD 4 28-09-2007 3:39 PM
Lip sync on Sky+ Optical Link Selmar Sky and Sky+ 1 21-12-2005 2:17 PM
Old 09-06-2008, 6:24 PM   #1 (permalink)
metalhead72's Avatar
Thanks: Gave 111, Got 132
Slow 'Audio/lip sync' from optical from Sky HD box ?
I've got an issue where when I connect my Sky HD box to my amp via optical the music is slow (and I mean slow) within the sky tv guide menu, Also lip sync whilst watching a program is total out of sync.
I don't experience this issue if I connect the optical cable from my TV to the amp (I connect the Sky HD box to the TV via HDMI). Also phono leads from the Sky HD box to the amp is fine..
what's causing this issue.. Is it the dreaded PSU issue ?
Home Cinema - Samsung LE40R88BD 40", Samsung HT-TX35R, Samsung BD-P1500, Samsung SM932MW, Sky HD, Sky BB 8Mb, URC8060 Kameleon 6, 30Gig Ipod Video, Sennheiser CX 300, Wharfedale Micro DAB system, Revo BLIK,Wii
metalhead72 is offline   Reply With Quote
Old 09-06-2008, 6:33 PM   #2 (permalink)
Conspicuous Member
mattclarkie's Avatar
Location: Real guitars don't have strings, they have 5 coloured buttons.
Thanks: Gave 425, Got 638
Re: Slow 'Audio/lip sync' from optical from Sky HD box ?
A slight delay is introduced by the box handling the DD. It can also be made worse by the picture processing in the TV, but when outputting via the TV speakers/optical out this is corrected by circuits in the TV.
In the services menu under Audio options is Optical Delay. You can set this to correct the lip sync, mine is set to 200ms which makes the issues un-noticable, for you it maybe different.
As for the slow music, I have had that a few times, it generally sorts itself after a few hours.
Originally Posted by r2001uk View Post
I thought DieEasySteave was called DiseasySteve for a moment, I almost had to hit the leper alarm!
Classic
mattclarkie is offline   Reply With Quote
Old 09-06-2008, 6:54 PM   #3 (permalink)
It weird ? As I said, if I connect the tv via optical to the amp its fine, but via the Sky HD box to the amp .. forget about it !! I don't mind keeping it like that but I don't think that I will get a true DD signal this way...
I've turned it over to one of the movie channels that's currently showing a film with DD and the DD indicator on the amp is not lighting up. If I connect the Sky HD box to the amp via optical the DD sign lights up.. Am I right in thinking that the Sky HD box only sends a stereo signal via HDMI
Old 09-06-2008, 8:01 PM   #4 (permalink)
Conspicuous Member
Thanks: Gave 4, Got 1,199
You will not get DD from a optical cable connected to your TV only stereo. The HDMI cable from a SKY HD box only carries stereo and if you could convert to 5.1 over the HDMI cable (DVD player etc) the TV still would not pass 5.1 via optical.
Andy98765 is offline   Reply With Quote
Old 09-06-2008, 8:14 PM   #5 (permalink)
Just rang Sky, there coming out on Saturday to hopefully replace the box.. I've experienced other issues with the box recently like reboots and fail recordings.
Old 09-06-2008, 9:13 PM   #6 (permalink)
lee12's Avatar
Thanks: Gave 71, Got 71
Holy Pilgrim,
I presume you're experiencing the problem when connecting your HD box to you Sammy HT-TX35R all in one... If so it's worth reading the thread on your amp here >
Samsung HT-TX35R/Samsung HT-X30R
There is a known issue with lip-sync with this amp, fortunately Samsung have realesed a firmware upgrade within the past couple of weeks. Somebody has has helpfully uploaded this - it's all in the past months worth of posts.
Hope this solves your issue
losing my edge
PSN bristolterra
lee12 is offline   Reply With Quote
Old 10-06-2008, 6:15 PM   #7 (permalink)
Yes, I applied the fix and it does indeed fix the issue with lip sync.. but people only experienced this if the optical cable was connected from the TV to the amp not directly from a Sky+/HD box to the amp. Hopfully a new Sky HD box will resolve this issue. Has anybody else had a swap out recently.. Do they swap it for a Pace/Samsung HD box ?
Old 14-06-2008, 4:35 PM   #8 (permalink)
Just an update, Sky came out today and swap out the box. They swapped it for a new box (had yellow stickers on it)
Model Number 607120V
Version Number 4E3009
Operating System Version 1.32A0E
EPG Software Version 5.10.j HD
audio or lip, box, optical, sky, slow, sync
