Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky HD
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Old 08-01-2007, 11:31 PM   #1 (permalink)
Chilaz's Avatar
Question Sky HD Video Sender- Help!?
Hi, I have recently purchased a nice new 27" HDTV for my bedroom - so far I am very pleased with it and the picture quality is great (using my PS2 linked via Component).
However I live in an area where TV reception is very poor and getting standard analogue and Freeview at any kind of decent quality is hard, to say the least.
In my living room I also have a Sky HD box that gets perfect signal (due to the fact that is satellite ). It would be great if I could get the same box upstairs but Sky's multiroom package really doesn't appeal...
So I have recently started looking at video senders having no idea what to look for I am a bit lost and am seeking advice...
What kind of picture would I get with these devices - I know it would not be HD quality but would it be close?
Could I get a decent one relatively cheaply < £50 ?
Chilaz is offline   Reply With Quote
Old 14-01-2007, 3:01 PM   #2 (permalink)
Thanks: Gave 14, Got 29
Re: Sky HD Video Sender- Help!?
A video sender is for standard TV. It will not lock to the HD frame rates. So the only solution is to feed the video sender with a normal TV feed from your Sky box and enjoy SD TV upstairs.
If you are really keen you could run HD component (wires) to your bedroom and use the sender for remote signals!
Cliff is offline   Reply With Quote
Old 14-01-2007, 8:20 PM   #3 (permalink)
Thanks: Gave 4, Got 11
I have a Digisender Gold which send signals from my Sky HD box to my bedroom. This is about 5 metres away in a straight line, through one wall on the same floor. I get a really good picture on my 23 inch lcd from this, and for some reason it even improved when my Sky+ was replaced to SkyHd. The only thing i would say is the search and scan banner (when press the blue button) is a bit jaggedy but this is no real problem. The main picture is well impressive. With the gold version you can hook upto 4 scart devices at a time, although i only use one. Of course my sky box can also be controlled remotely using a sky+ or skyHd remote. Hope this helps.
JimmyT is offline   Reply With Quote
Old 15-01-2007, 10:46 PM   #4 (permalink)
Chilaz's Avatar
Thanks for the help Anyway I don't think wiring the connection would be very convenient as its about 20m from my TV to the Sky Box downstairs, not to mention all the wall drilling ...
What kind of quality would I get with one of these receivers at this range considering it has to go through about 3 walls (2 along and up a floor.)
And finally... Could anyone recommend a box with good quality and signal with a scart socket, only need the one really.
Old 16-01-2007, 9:46 AM   #5 (permalink)
gmp
Thanks: Gave 27, Got 26
I used to use AEI sender to send signal from sky box (now hd box) from lounge to 3rd floor loft conversion. Was ok but now we've got hd become more fussy about quality. Now running 15m of component and optical (£25 for both) upto loft as we have have projector (with home cinema sound system) as well as second lcd in loft. Take our cables out through corner of window frame in lounge and up outside of house and back in same way.
gmp is online now   Reply With Quote
Old 16-01-2007, 1:28 PM   #6 (permalink)
Thanks: Gave 7, Got 0
I had an AEI x4 Gold as well. Although the picture was good the remote control never worked from upstairs.
I took it back and got a different brand (cant remember which) from maplin - go into a store they have lots - it cost about £25
The picture is good I would say the quality of standard arial based TV. And for a remote solution I used
http://reallycleverhomes.co.uk/acata...ender_set.html
The remote worked first time from upstairs. And if you add the two together it was still about half the price of the AEI from Maplin.
It is a good setup if you dont/cant drill and rewire your house. However sometimes the picture does go screwy - this is normal down to the microwave being used, my Airport Express being used or the lady next door in her bedroom using something that vibrates....
On the whole its a good solution so good luck!
simonlote is offline   Reply With Quote
sender, sky, video
