Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky HD
Latest AVForums Movie Reviews
Music Man, The Blu-ray ReviewUgly Truth, The Blu-ray ReviewEmpire Of The Ants - Original Motion Picture Soundtrack CD ReviewThe Toolbox Murders Blu-ray ReviewDungeons & Dragons: Wrath of the Dragon God Blu-ray Review
The Book of Eli - Original Motion Picture Soundtrack CD ReviewInvention of Lying, The Blu-ray ReviewSmokin' Aces 2: Assassins' Ball Blu-ray ReviewDorian Gray Blu-ray ReviewL'armée du crime Blu-ray Review
Old 25-12-2006, 12:53 AM   #1 (permalink)
Adama's Avatar
Thanks: Gave 50, Got 54
Smile Upgraded to 1 Terabyte without removing warranty sticker
Just upgraded with one of these http://www.scan.co.uk/Products/Produ...source=froogle and two of these http://www.ebuyer.com/UK/product/108...FR5dMAodvhMIKg after using Skycopy+ beta to clone my original drive I am now up to 1000gb - minus 140gb for Sky's own use.... and it works! Planet Earth-2%, I Robot-2% Star Wars-3%... God I'm so smug... and all for about £350
Adama is offline   Reply With Quote
TaylorWJ (27-12-2006), vinz420 (18-07-2007)
Old 25-12-2006, 5:18 PM   #2 (permalink)
Re: Upgraded to 1 Terabyte without removing warranty sticker
lm interested, how does it work then?
Spit is offline   Reply With Quote
Old 25-12-2006, 5:41 PM   #3 (permalink)
Giblets2's Avatar
Thanks: Gave 516, Got 166
Nice avatar by the way Adama - ni!
I'm guessing this is a dual drive SATA box with an external power supply and some sort of RAID hardware built in (set in JBOD mode for this application). That's certainly a good price for what it is if that's the case and it's exactly what I was looking for when I erroneously bought a Nexus Drive-A-Way, which I got refunded from Novatech.
Can you let us all know if that's the case, particularly the external PSU aspect? Thanks.
One good thing about the cold is finding things in your coat pockets that you put there a year ago...
Giblets2 is offline   Reply With Quote
Old 25-12-2006, 6:53 PM   #4 (permalink)
But how do you install it, where?
Old 25-12-2006, 11:30 PM   #5 (permalink)
Giblets2's Avatar
Externally, with a SATA cable going into the box to plug into the mobo connection in place of the internal drive.
Old 25-12-2006, 11:38 PM   #6 (permalink)
Mighty Gaz
Posts: n/a
i will only be impressed when you get me... a shrubbery!
Old 26-12-2006, 9:52 AM   #7 (permalink)
Giblets2's Avatar
Shouldn't that be a 'shwubberwy!' Eckie-eckie-eckie-fdang... ni *shut up!*
Old 26-12-2006, 10:29 AM   #8 (permalink)
Thanks: Gave 38, Got 20
A post like this with no instructions or advice seem pure "smugness". Perhaps some instructions or advice on how it was done could promote you from "smug git" to "forum legend" for those who might be considering something similar!
Bernie Steak is offline   Reply With Quote
Old 26-12-2006, 11:15 AM   #9 (permalink)
Tarbat's Avatar
Thanks: Gave 112, Got 271
Some details of the Thecus 2050 here - http://www.thecus.com/products_over.php?cid=1&pid=3
Product info
Looks like it uses external power
Sony KDS-55A2000 (1920x1080 SXRD) : Sky+HD (HDMI-AUTO) : XBox360 Elite (HDMI-1080p) : Yamaha YSP-800 : Harmony Remote 675
Tarbat is offline   Reply With Quote
Old 26-12-2006, 11:39 AM   #10 (permalink)
Adama's Avatar
Giblets got it! Although I had to use a SATA-to-eSATA lead to connect it to the mother board... Took the original drive out(without removing it from its caddy or touching its sticker), connected it to a SATA Pci card in my PC. Then copied the image over to the Thecus N2050(This contains two new Western Digital WD5000KS 500gb's - buy these seperately - and is set to RAID 0 by a switch at the back so they appear as one big volume) which is also connected to the Pci card. Then replaced the original drive back in the Sky box(safest place for it) but only reconnecting the fan, I found the main fan wouldn't power down if I didn't. Then run the SATA-to-eSATA lead from the motherboard thru the hole in the left side (leave the grill off). The only downside to the setup is the N2050 - having it's own external power supply - doesn't power down(although the drives themselves must spindown). The Sky box will crash if you try to access the drive when its powered down. The N2050 does have a fan (the drives do get warm, though no hotter than the ones in your PC) but I don't know how long it would last if you left it on for ever. I turn every thing off at night, unless there's a planner recording due... Sky have made a stick-for-their-own-backs showing all six Star Wars movies in HD on New Years Day - Theres gonna be a lot of full Hard drives!
Giblets2 (26-12-2006), mateybloke (27-12-2006), robfitzp (27-12-2006), suniil (17-03-2007)
Old 26-12-2006, 11:47 AM   #11 (permalink)
Adama's Avatar
Smile Re: Upgraded to 1 Terabyte without removing warranty sticker
Sorry I took so long to post - Drunk - Hangover - Couldn't upload the picture - in that order... If anyone's really interested I'll post a shoping list of Links and answer any queries
Old 26-12-2006, 1:23 PM   #12 (permalink)
mitchec1's Avatar
Thanks: Gave 174, Got 189
yes please
mitchec1 is offline   Reply With Quote
Old 26-12-2006, 3:15 PM   #13 (permalink)
Thanks: Gave 104, Got 154
Don't talk too soon we might end up with 8% low bit rate showings.
My Set Up http://www.avforums.com/forums/members-home-cinema-gallery/382398-t8oos-home-cinema.html
Living Room: Panny PTAE900-Sammy 40"-IstarHD-SkyHD-360 Elite-PS3-Wii-Onkyo SR605-Harmony 895-7TB Networked Media-7TB Back Up Bedroom: Sammy 32"-Yammy YSP 800-IstarHD-SkyHD-360 Elite-PS3-Harmony 885. Xbox T8OO PS3 T-8-0-0
T800 is offline   Reply With Quote
Old 26-12-2006, 7:15 PM   #14 (permalink)
Adama's Avatar
Here's what I used for my upgrade:
2x Western Digital WD5000KS
1x Thecus N2050
1x External SATA (L type) to eSATA (I type) data cable
1x Serial ATA 150/300 data cable
1x Serial ATA Power Interface Cable
1x Serial ATA 2 Port PCI Card
and here's the cheapest links as of 26 Dec 06
http://www.ebuyer.com/UK/product/48670
http://www.cablecity.co.uk/product_i...roducts_id=925
http://www.cablecity.co.uk/product_i...roducts_id=385
http://www.cablecity.co.uk/product_i...roducts_id=388
Even with p&p the whole lot came under £350... right I'm off to the pub
Giblets2 (26-12-2006), Kieron (06-01-2007), robfitzp (26-12-2006)
Old 26-12-2006, 9:06 PM   #15 (permalink)
Comer's Avatar
Thanks: Gave 17, Got 64
Do you loose 140Gb from each 500GB HD or does the sky box see the two drives as one?
VW60 Black Pearl, Panasonic 37PX80B; Onkyo TX-SR605 AV Receiver; Monitor Audio B2s (fronts & surrounds); Monitor Audio ASW100; Monitor Audio Bronze Centre; Blu-Ray HCPC; I miss the taste of meat
Comer is offline   Reply With Quote
removing, sticker, terabyte, upgraded, warranty
Copyright © 2000-2010 M2N E. & O. E.
