No Channel 5
Old 22-05-2007, 3:23 PM   #1
5,173, Level: 17
Points: 5,173, Level: 17 Points: 5,173, Level: 17 Points: 5,173, Level: 17
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 91, Got 20
No Channel 5
I had channel 5 on my old CRT (SKY HD box), but now with my new LCD tv, I get no signal....very strange.....anyone else have this?
Old 22-05-2007, 3:45 PM   #2
Fugitivewolf6
Posts: n/a
Re: No Channel 5
take it u mean 5 through sky.. and you getting the blue screen saying no sat signal being recieved.. have you checked sat cable going into box? make sure no wires touching and plugs secure.
Old 22-05-2007, 4:06 PM   #3
5,173, Level: 17
Activity: 0.8%
Re: No Channel 5
I didnt check as it's the only channel not working....it's through my SKY HD box, if it were to be the cable, surely other channels would not work?
Old 22-05-2007, 4:13 PM   #4
Fugitivewolf6
Posts: n/a
Re: No Channel 5
normally yes, youd find a group not working.... but 5 working ok on mine, so not a broadcast problem. Easiest thing to check first... or you could try to froce an update.
The Captain (22-05-2007)
