Will recording continue if programme over runs???
Old 22-05-2007, 9:43 AM   #1
4,055, Level: 15
Points: 4,055, Level: 15 Points: 4,055, Level: 15 Points: 4,055, Level: 15
Activity: 3.7%
Activity: 3.7% Activity: 3.7% Activity: 3.7%
Thanks: Gave 28, Got 5
I am planning to record the Champions League final tomorrow on SSHD1 & was wondering if the programme over runs will the recording continue or will it stop when the programme was scheduled to finish?
Should i use the manual recording instead?
Old 22-05-2007, 9:52 AM   #2
hottstuff's Avatar
7,467, Level: 20
Points: 7,467, Level: 20 Points: 7,467, Level: 20 Points: 7,467, Level: 20
Thanks: Gave 147, Got 159
Re: Will recording continue if programme over runs???
That won't go to extra time mate , so let it automatically add 5 mins each end.
Old 22-05-2007, 10:08 AM   #3
4,553, Level: 16
Points: 4,553, Level: 16 Points: 4,553, Level: 16 Points: 4,553, Level: 16
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 5, Got 44
Sky are normally good at extending the EPG - so you should be fine. However, I have found this only works if you do not have any padding set up.
If you don't want to trust them, just either record the next programme, or put in a manual recording for, say, the next half hour.
Old 22-05-2007, 10:12 AM   #4
4,055, Level: 15
Activity: 3.7%
How do you know?
Old 22-05-2007, 10:57 AM   #5
Neil Watson's Avatar
6,498, Level: 19
Points: 6,498, Level: 19 Points: 6,498, Level: 19 Points: 6,498, Level: 19
Thanks: Gave 9, Got 81
It worked a treat (a bit to well in fact) on the FA Cup final at the weekend. Was scheduled to take up 16% on BBDHC so had cleared out 23% just to be sure as didn't think about match going into extra time, only that the info isn't always great in its guessing When I got home it had used 26% and had zapped one of the films I had in my planner so as to record the extra time and post match commentry
Old 22-05-2007, 12:09 PM   #6
Mattk84's Avatar
12,231, Level: 26
Points: 12,231, Level: 26 Points: 12,231, Level: 26 Points: 12,231, Level: 26
Thanks: Gave 156, Got 137
Why not just record the programme scheduled to start after the footie as well to be on the safe side ?
Old 22-05-2007, 6:04 PM   #7
2,514, Level: 11
Points: 2,514, Level: 11 Points: 2,514, Level: 11 Points: 2,514, Level: 11
Thanks: Gave 8, Got 5
Too right...Liverpool will give 'em a four-nil head start this time and beat them in normal time
But i bet Jose will still say the best team lost
