Originally Posted by ttdriver Hi Guys,
Ok I am confused, When sky show a film or tv series on their HD channels is it true Hd (720 p upwards) or just upscaled stuff?
The reason I ask is that I am sure I have seen films advertised on sky movies HD that are not released on HD-DVD nor Blu-Ray so i can only assume they are just upscaled broadcasts, am I correct?
Dave |
SKY1HD, SKYArtsHD and SKY Sports HD show a mixture of upscaled SD and native HD and if you can't tell by looking then this is indicated in the EPG and the type of DOG used.
SKY Movies HD is a native HD channel (as is Disco, NG and History) as there is a huge back catalogue of native HD movies since anything shot on 16mm film upwards can be scanned into a computer to generate a 1080p master. Spend a bit more money and they can be cleaned up resulting in a much nicer transfer and spend a lot you can restore a movie and it tends to look as good if not better than when it was made
Movies were being broadcast in HD years before HD-DVD and Blu-ray even hit the drawing boards
