pioneer pdp r05fe sky hd fix (help)
Old 04-12-2006, 8:46 PM   #1
3,859, Level: 14
Points: 3,859, Level: 14 Points: 3,859, Level: 14 Points: 3,859, Level: 14
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
Thanks: Gave 1, Got 6
had poineer come out and use there new fix update for sky hd today and now i have switched back from component to hdmi i get a blank screen no sound no picture nothing using hdmi
any ideas
Old 05-12-2006, 1:25 PM   #2
5,999, Level: 18
Points: 5,999, Level: 18 Points: 5,999, Level: 18 Points: 5,999, Level: 18
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 87, Got 123
Re: pioneer pdp r05fe sky hd fix (help)
Have you swicthed HDMI on in the Pio menu?
Old 05-12-2006, 6:18 PM   #3
3,859, Level: 14
Activity: 0.6%
yes and still nothing
Old 05-12-2006, 6:46 PM   #4
brendan_dj's Avatar
18,847, Level: 33
Points: 18,847, Level: 33 Points: 18,847, Level: 33 Points: 18,847, Level: 33
Thanks: Gave 61, Got 117
when you press the appropriate input button on your Pioneer remote, it should display some text in the corner of the screen for a few seconds, even if there is no signal.
Can you tell us EXACTLY and in full what it says in the corner. Everything including the input number and the time.
Old 05-12-2006, 7:25 PM   #5
Conspicuous Member
Woodywizz's Avatar
16,501, Level: 31
Points: 16,501, Level: 31 Points: 16,501, Level: 31 Points: 16,501, Level: 31
Thanks: Gave 1,274, Got 1,666
This has happened to me a couple of times - not with a Pio though. The "handshake" may have been lost. This can be rectified by simply removing the HDMI cable from the back of the media box, and reinserting again.
Old 05-12-2006, 10:20 PM   #6
3,859, Level: 14
Activity: 0.6%
pressed input 3 and in the corner came up input 3 hdmi 10:02 and blank where it normally has lines is this any use
Old 06-12-2006, 6:20 PM   #7
3,859, Level: 14
Activity: 0.6%
any ideas
