Sky HD and Denon S 301
Old 01-07-2006, 1:32 PM   #1
apgp
Posts: n/a
Hi to all,
As far as the sound connections go I dont see a problem, this can be achieved by connection the Optical Dig out from the Sky HD box to the Optical Dig in on the S-301.
But the picture is a different situation & this is where I need some advice !!
If I connect the Sky HD to my Sony plasma I need to do it via component (no HDMI), but how do I get a picture signal from the S-301(DvD) to the telly ??
I presume the sound from the DvD is not an issue as this is controlled internally within the S-301 & output irrespective of connections
Thanks in advance
Old 02-07-2006, 9:28 AM   #2
apgp
Posts: n/a
There must be someone who has this set up ??
Old 02-07-2006, 10:35 AM   #3
16,736, Level: 31
Points: 16,736, Level: 31 Points: 16,736, Level: 31 Points: 16,736, Level: 31
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 42, Got 341
Well if you can't use HDMI and you don't want use its RGB scart or S-Video output then you'll need a component switcher.
