Originally Posted by PEHowland HDTV uses MPEG4 and there is absolutely no mention of this with the card. I would be extremely surprised if this could receive, let alone record, Sky HD. There is no mention of HDCP support either. Avoid it. |
Think you are misunderstanding what PC capture cards do - they just demodulate the RF signal into a transport stream, and in some cases filter out the various MPEG streams. They don't do anything to process the video or audio streams - unless they are the relatively rare high-end MPEG2 hardware decoding cards with their own video outputs - which aren't suitable for HD.
The PC itself does the MPEG2 or MPEG4 H264 decoding - not the card.
HDCP is purely a function of the DVI or HDMI output processing - it is not part of the broadcast itself - though in many implementations it is possible for the broadcaster in a closed broadcast system (like Sky HD - which the BBC are not really a part of, they are just compatible with it) to add a flag which forces the receiver / player to implement HDMI.
The key thing for the BBC HD trial is the broadcast modulation scheme. At the moment the BBC are using DVB-S (as they are sharing a transponder with two BBC One regional feeds) - however if they move to DVB-S2 and you have a DVB-S only card you'll be stuffed.
