Question about SKY HD sound
Old 30-06-2006, 5:45 PM   #1
stotty06
Posts: n/a
I just got Sky HD installed today and all seemed ok when the installer had left. But after a while the sound started cutting off and back on and when it came back on it sounds different and sharp and rough are the only ways i can describe it. Can anyone help me with how to get the sound back to normal? Thanks.
Old 30-06-2006, 6:33 PM   #2
2,771, Level: 12
Points: 2,771, Level: 12 Points: 2,771, Level: 12 Points: 2,771, Level: 12
optical via AV Amp or analogue to TV connection?
Old 30-06-2006, 10:23 PM   #3
4,518, Level: 15
Points: 4,518, Level: 15 Points: 4,518, Level: 15 Points: 4,518, Level: 15
Thanks: Gave 1, Got 1
I've had this every now and then. Putting the box into standby seems to sort it out.
Cheers,
Alex
Old 30-06-2006, 11:30 PM   #4
fozzieAV's Avatar
3,449, Level: 13
Points: 3,449, Level: 13 Points: 3,449, Level: 13 Points: 3,449, Level: 13
Thanks: Gave 19, Got 17
That'll certainly stop any sound problems. Unfortunately, it'll also stop you from seeing a picture
