new to sky HD, question about sound outputs
Old 23-11-2009, 3:26 PM   #1
3,219, Level: 13
Points: 3,219, Level: 13 Points: 3,219, Level: 13 Points: 3,219, Level: 13
Thanks: Gave 12, Got 0
Can someone help
just booked to have my sky + box replaced with a nice shinny new sky hd box but can some one tell me if the hd boxes have a coax audio output or is it the same as the sky + boxes and ony have optical or L & R outputs as my amp only has coax inputs and the converter i bought caused nothing but problems
many thanks in advance
Old 23-11-2009, 3:27 PM   #2
70,130, Level: 64
Points: 70,130, Level: 64 Points: 70,130, Level: 64 Points: 70,130, Level: 64
Activity: 99.8%
Activity: 99.8% Activity: 99.8% Activity: 99.8%
Thanks: Gave 1,255, Got 3,019
Award-Showcase
It's not helpful - but they do not have co-axial outputs.
Old 23-11-2009, 3:35 PM   #3
3,219, Level: 13
thanks for the quick reply oh well looks like an excuss to upgrade the amp then, just have to sweet talk the wife
thanks again
Old 23-11-2009, 3:36 PM   #4
SevloW's Avatar
5,544, Level: 17
Points: 5,544, Level: 17 Points: 5,544, Level: 17 Points: 5,544, Level: 17
Thanks: Gave 522, Got 592
Originally Posted by razor1979 View Post
Can someone help
The Samsung's have both (would imagine Pace/Amstrad as well)
razor1979 (23-11-2009)
Old 23-11-2009, 3:39 PM   #5
3,219, Level: 13
so depending on what box i get it may have a co-axial output
Old 23-11-2009, 3:40 PM   #6
SevloW's Avatar
5,544, Level: 17
As the boxes are standard then you will have both co-ax/optical audio out on the back of the box.
Old 23-11-2009, 3:51 PM   #7
Conspicuous Member
18,811, Level: 33
Points: 18,811, Level: 33 Points: 18,811, Level: 33 Points: 18,811, Level: 33
Activity: 16.7%
Activity: 16.7% Activity: 16.7% Activity: 16.7%
Thanks: Gave 93, Got 1,424
All current Sky HD boxes have both optical and digital coaxial audio output. The original Thomson boxes had only optical digital audio out.
Old 23-11-2009, 3:52 PM   #8
mossym's Avatar
Location: You'd get your feet wet getting here, but the Guinness is worth it...
24,851, Level: 38
Points: 24,851, Level: 38 Points: 24,851, Level: 38 Points: 24,851, Level: 38
Activity: 11.8%
Activity: 11.8% Activity: 11.8% Activity: 11.8%
Thanks: Gave 598, Got 1,310
you should still get the new amp..
Old 23-11-2009, 3:57 PM   #9
technowizard's Avatar
4,436, Level: 15
Points: 4,436, Level: 15 Points: 4,436, Level: 15 Points: 4,436, Level: 15
Thanks: Gave 31, Got 54
All the new boxes have both optical and coaxial.
Old 23-11-2009, 4:02 PM   #10
3,219, Level: 13
thanks guys at least i can put the amp on hold until after xmas and then hopefully get a better one in the sales
sorry just reread that so your saying all boxes have both but you cant use the co-axial output , so whats the point in having it
Old 23-11-2009, 4:05 PM   #11
SevloW's Avatar
5,544, Level: 17
You can use either - the coax or the optical - they both work. (Page 66 of the manual shows you your options)
Old 23-11-2009, 4:10 PM   #12
4,436, Level: 15
comment removed
Old 23-11-2009, 4:15 PM   #13
SevloW's Avatar
5,544, Level: 17
Originally Posted by technowizard View Post
Is it enabled with the New EPG because my amstrad's coax output definately doesn't work (old epg)?
Should not make any difference re epg so you may have a faulty box. I cant check at the moment as son is playing xbox. Will have a look when he is finished.
Old 23-11-2009, 4:18 PM   #14
4,436, Level: 15
comment removed
Old 23-11-2009, 4:21 PM   #15
3,219, Level: 13
much appericated
Old 23-11-2009, 4:36 PM   #16
KevIW's Avatar
6,475, Level: 19
Points: 6,475, Level: 19 Points: 6,475, Level: 19 Points: 6,475, Level: 19
Thanks: Gave 18, Got 18
Coax defo works! Father in law uses it as I will next week when mine in installed.
Old 23-11-2009, 4:42 PM   #17
4,436, Level: 15
comment removed
Old 23-11-2009, 4:43 PM   #18
KevIW's Avatar
6,475, Level: 19
Yes he has Pace but it worked prior to that as I set it up to his amp.
Old 23-11-2009, 4:47 PM   #19
4,436, Level: 15
Sorry, i take back all my previous posts.
It turns it does work regardless of EPG
The first time i tried it wasn't playing ball. But it defo works now
Old 23-11-2009, 4:54 PM   #20
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Points: 20,236, Level: 34 Points: 20,236, Level: 34 Points: 20,236, Level: 34
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 369, Got 613
Maybe you should go back & edit your earlier post in case someone else reads it in isolation after doing a search?
Old 23-11-2009, 5:39 PM   #21
3,219, Level: 13
thanks guys for all your help shame i have to wait untill the 7th December to get it installed
Old 23-11-2009, 6:20 PM   #22
KevIW's Avatar
6,475, Level: 19
I know its a pain I have to wait til 4th Dec!
Old 23-11-2009, 9:37 PM   #23
70,130, Level: 64
Activity: 99.8%
Award-Showcase
Apologies - I thought they were all the same - mine doesn't have co-axial.
Try another excuse for a new amp though - I just did and it's well worth it.
