Sky hd box
Old 23-11-2009, 10:49 AM   #1
1,040, Level: 7
Points: 1,040, Level: 7 Points: 1,040, Level: 7 Points: 1,040, Level: 7
Thanks: Gave 5, Got 0
Sky hd box
I'm having Sky HD installed next Monday and asked the installallation company for a Samsung box as I read these were the best.
They have told me that they don't use Samsung as they had "problems" with them and only use Pace! Then said that they don't get supplied anymore with Samsung.
Can this be true? Are Samsung no good?
Old 23-11-2009, 11:16 AM   #2
The SMF's Avatar
3,842, Level: 14
Points: 3,842, Level: 14 Points: 3,842, Level: 14 Points: 3,842, Level: 14
Activity: 9.8%
Activity: 9.8% Activity: 9.8% Activity: 9.8%
Thanks: Gave 15, Got 88
sounds like rubbish to me
Old 23-11-2009, 11:21 AM   #3
SevloW's Avatar
5,544, Level: 17
Points: 5,544, Level: 17 Points: 5,544, Level: 17 Points: 5,544, Level: 17
Thanks: Gave 522, Got 592
I would not worry about it, Pace boxes are fine anyway. Most of the boxes have some 'quirks'. I have had both a Pace and now have a Samsung which works just fine (the Pace was recalled because earlier models had a fault).
They look the same so there is no cosmetic difference.
Old 23-11-2009, 11:32 AM   #4
1,040, Level: 7
Thumbs up
Thanks for that Sev, What does the new Pace box look like?
Old 23-11-2009, 12:29 PM   #5
Conspicuous Member
18,811, Level: 33
Points: 18,811, Level: 33 Points: 18,811, Level: 33 Points: 18,811, Level: 33
Activity: 16.7%
Activity: 16.7% Activity: 16.7% Activity: 16.7%
Thanks: Gave 93, Got 1,424
I think he's already told you. A Samsung by the sound of things...
Old 23-11-2009, 12:41 PM   #6
1,040, Level: 7
OK then Whats a Samsung look like
Old 23-11-2009, 12:44 PM   #7
7,103, Level: 20
Points: 7,103, Level: 20 Points: 7,103, Level: 20 Points: 7,103, Level: 20
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 35, Got 45
Had HD upgraded last week - and the engineer tried 2 new Samsung units, out of branded boxes, but both had faults where he could not get a picture.
He then pulled a Pace unit from a plain brown box - and this worked fine. I asked whether this was a refurbished unit and he said that they only put refurbs to replace existing faulty units - not on new installations (whether that is right or not).
The enginner then called a couple of his mates who all picked up new Samsung boxes that morning - to see if they had problems, so there may be something in the Samsung quality question...
Old 23-11-2009, 12:44 PM   #8
The SMF's Avatar
3,842, Level: 14
Activity: 9.8%
all sky hd boxes look the same
Old 23-11-2009, 1:21 PM   #9
2,032, Level: 10
Points: 2,032, Level: 10 Points: 2,032, Level: 10 Points: 2,032, Level: 10
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 0, Got 55
Except the new smaller amstrad on test.
Old 23-11-2009, 1:51 PM   #10
SevloW's Avatar
5,544, Level: 17
http://www.parabolic.co.uk/catalog/i...y-HD%20BOX.jpg
Old 23-11-2009, 7:31 PM   #11
1,040, Level: 7
Ty vm Sev Cant wait to get connected now
Old 23-11-2009, 7:55 PM   #12
3,885, Level: 14
Points: 3,885, Level: 14 Points: 3,885, Level: 14 Points: 3,885, Level: 14
Samsungs not getting installed is a load of parp.
They are getting installed, and with the NEW EPG from the off.
