Originally Posted by grahamlthompson I don't follow that argument at all |
You don't follow that 1080p/50 has more resolution than 1080i/50?
SKY HD is 1920 x 1080 delivered in two fields of 1/50 sec each. That's an identical resolution to a 1080p25 1920 x 1080 delivered in a single field of 1/25 sec. The interlaced signal may have motion artefacts but it's got the same number of pixels in each full frame. BBC HD and ITV HD on DVB-S transponders use 1440 x 1080i. Nobody transmits 1080p50 which needs way too much bandwidth.
I know but the point remains that "1080i" and "1080p" are not the same.
I guess it's fair to say that 1080i and 1080p as used most often (1080i/50 and 1080p/24) are pretty much the same but consoles (for example) are just one source of 1080p/60 content and it's confusing to not make the distinction clear and all the technical gibber about transponders doesn't help people understand.
In any case whatever the signal is (576i or 1080i), the resolution of the displayed picture is identical on a HD matrix display which has to display it's native pixel count.
Of course. The resolution is the same - the picture isn't. and the same is true of various TVs' handling of 1080i.
