Is this possible? Installation query
Old 23-11-2009, 9:46 AM   #1
8,853, Level: 22
Points: 8,853, Level: 22 Points: 8,853, Level: 22 Points: 8,853, Level: 22
Thanks: Gave 3, Got 4
Hi All,
Currently got 2 Sky+ units in the house (both in the same location - 2nd is running loop through to other TV's - one with a magic eye). We have the full channel package with the multiroom option.
Now we want to upgrade 1 of the boxes to HD. Now this box would need to be in a different location. What are the chances of the sky installer putting a 2nd dish up and running cables directly to this location - I want to keep the 2nd sky+ box where it is in case we want to use it for something else.
If not is there anyway to get a HD box without him needing to visit and avoid the installation cost - cos I'm damn sure I can plug a hdmi, power and 2 cables from the existing sky+.
Cheers all.
Old 23-11-2009, 10:06 AM   #2
12,554, Level: 26
Points: 12,554, Level: 26 Points: 12,554, Level: 26 Points: 12,554, Level: 26
Activity: 38.2%
Activity: 38.2% Activity: 38.2% Activity: 38.2%
Thanks: Gave 217, Got 318
You presumably have a quad LNB, so you can swap it for an octo and keep the single dish.
Old 23-11-2009, 10:14 AM   #3
8,853, Level: 22
Yes we have a quad lnb. Would a sky engineer carry or put up an octo lnb though?
Old 23-11-2009, 11:01 AM   #4
3,204, Level: 13
Points: 3,204, Level: 13 Points: 3,204, Level: 13 Points: 3,204, Level: 13
Originally Posted by 1ofaKind View Post
Hi All,
Cheers all.
Can I ask how you got around the issue of your remote controlling both Sky+ boxes? I've just taken delivery of an HD box (replacing a standard box) that also resides in the same place as an existing Sky+ box. I assumed the HD remote and Sky+ remote would use different IR frequencies. Whilst one won't turn the other on I have found that the Sky+ remote will control the HD box... means I spend a lot of the time shouting at the kids!!!
Old 23-11-2009, 11:17 AM   #5
28,189, Level: 40
Points: 28,189, Level: 40 Points: 28,189, Level: 40 Points: 28,189, Level: 40
Activity: 95.3%
Activity: 95.3% Activity: 95.3% Activity: 95.3%
Thanks: Gave 39, Got 2,263
It's not cheap but this will do the trick
Global SPC4 Super Plus Combiner
Old 23-11-2009, 11:24 AM   #6
3,052, Level: 13
Points: 3,052, Level: 13 Points: 3,052, Level: 13 Points: 3,052, Level: 13
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 13, Got 117
You can also use this, I think you would have to cover the receiver on the front of the box and use the magic eye.
SkyEye Multi HD - FAQ
