Originally Posted by HDCriticalFan As a rule of thumb I always ask people what height they had their previous screen ... which they were happy with for years. Then I ask them why they have put their new plasma half way up the wall !!!
There is no doubt in my mind that, for comfortable long term viewing, you need to have you eye level with the middle of the screen (or even just above the middle). Being level with the bottom is not good ... having the screen even higher than this is madness.
You might just get away with it in a "proper" home cinema where you just watch a film for 90 minutes or so (especially if you have cinema style seats). To spend a whole evening with a TV it simply has to be lower.
I would reckon on sitting 7-8 feet from a 42 inch screen. But it depends on the material and your personal preference. Made-for-TV shows can be viewed from further away ... detailed "landscape" movies repay sitting closer.
Regards |
Agree with eveything you say - the reason the TV is the height it is is because I live in a new-build where the builders had 'helpfully' put the power socket and Scart etc already built into the wall in anticipation that buyers would wall mount their TVs. Problem is they put them too high - if I were to move my TV even an inch lower down the wall the top of the sockets would become visible.
It annoyed the hell out of me first but I've sort of got used to it. However, as discussed, now I've got HD I'm tempted to get it off the wall and on a pedestal stand (which I bought and never used). It'll then be at a better height and a bit closer to me. To get 7-8 feet from it though I'd either have to move the settee away from the wall towards the TV, or have the TV away from the wall, both of which would look daft.
Of course nothing's simple in life - there's also an armchair which would have to be removed and put God knows where and the small matter of an electric fire which the TV is mounted above. I'd have to take it off the wall if the TV is to come down.
Oh well, I'll have a think. Thanks for the replies
