04-03-2007, 12:15 PM
#1 (permalink)
Thanks: Gave 97, Got 101
Sky BB WITHOUT their router
Has anyone managed to use their existing router and not install the sky/Netgear router
I have a Netgear DG834GT all set up and working nicely with 3 vista pc's - 2 xbox 360's - 2 Xbox - 2 PSP's - 1 PDA
AND do not want to mess it up with their unit
Any pointers in the right direction as the officail line is you have to use their unit
Tag McLaren DVD32FLR, Tag McLaren AV32R SP 192 BP 7.1EX DAB, Tag McLaren 100x5R,Tag McLaren 100x5R,Tag McLaren 100x5R,Aphrodite 192 dacs with 100x3R Chieftec Case/Gigabyte GA-EP45-DS5 with Quad core 2.67ghz Crucial 4gb ram 10.0tb maxtors with Windows Home Server PP3 and LG Bluray/HD DVD Player
Reason: the usual spelling mistakes :)
04-03-2007, 1:22 PM
#2 (permalink)
Thanks: Gave 0, Got 69
Re: Sky BB WITHOUT their router
Sky use that router aswell
No you can't use your own one because one of the agreement with Sky is you must use the equipment they supply.
04-03-2007, 1:24 PM
#3 (permalink)
you can use other routers
i just cannot find the site i found the other day that explained how quite easily
04-03-2007, 1:43 PM
#4 (permalink)
I didn't say you can't use other equipment.
I said As part of your terms and conditions of signing up to Sky broadband, you agreed to use their hardware that they supply
Because you have same router sky provide you could swap them easily or Sky is locked down with your username and password for use on Sky so you need to do some hacking of the router to get it and then use it on yours.
04-03-2007, 1:48 PM
#5 (permalink)
misunderstanding
Their T and C's are a joke
i've got 3 sky + and one Sky HD i pay them enough
I just would like to know HOW i can get my log in name for sky so i can alter the login on my netgear router
I will leave their unit in the box i dont want it
on my system at the moment i have BT bb their homehub has never been used still in box
In the log in page of my router i have A£££££££££Cross+HG£>BT££££.Com and obviously my password
does anybody know if you have this info from sky to use another router
04-03-2007, 2:17 PM
#6 (permalink)
Thanks: Gave 0, Got 10
Have you tried the Skyuser forum/ ?
04-03-2007, 6:11 PM
#7 (permalink)
Thanks: Gave 13, Got 41
It's all here, scroll down to 'URL Injection'.
http://www.asininemonkey.com/netgear...t-hacking.html
I did it and |I now use my Linkseys router as the Sky one keeps locking up. Still waiting for a replacement.
04-03-2007, 6:25 PM
#8 (permalink)
cheers guys
read that earlier just the info i needed
thanks
05-03-2007, 2:05 PM
#9 (permalink)
Thanks: Gave 14, Got 7
The URL Injection link sounds very complicated and probably beyond many, myself included. Can anyone give an idiot's version. I assume this gives you the password to use on your existing router.
If you swap routers (I already use a Netgear) is it straightforward to connect other devices?
17-03-2007, 11:07 PM
#11 (permalink)
Conspicuous Member
Thanks: Gave 148, Got 596
can't you just use their router/modem and connect your own router/access point into the ethernet port of it? Effectively just using it for the ADSL bit and your own stuff for the wireless bit?
eg currently i use an old Netgear 824M wireless router/modem but have the wireless bit disabled. I have an 'n' wireless access point which connects to the ADSL modem via ethernet. Could I just switch out the modem?
27-03-2007, 4:57 PM
#12 (permalink)
Thanks: Gave 88, Got 18
is the sky bb router a router only or modem/router? Is it any faster over a voyager 2110?
27-03-2007, 6:39 PM
#13 (permalink)
Thanks: Gave 8, Got 80
Its a Netgear DG834GT and yes it is a modem\router.
And yes you can add an Access Point and use that instead.
27-03-2007, 9:36 PM
#14 (permalink)
is the netgear one better?
