Awful internet speeds - Sky to blame?
Old 17-02-2007, 6:26 PM   #1
2,545, Level: 11
Points: 2,545, Level: 11 Points: 2,545, Level: 11 Points: 2,545, Level: 11
Thanks: Gave 9, Got 9
I've been a loyal Zen customer over the last 2 years, and made the move to ADSL in November after being on a fixed broadband service - the lure of 8mb seemed too appealing!
However from December, I've had problems with my line speed dropping to a whopping 129 kb/s. It has been as high as 4200kb/s, but something intermitendly keeps hitting my line and it gradually drops and it will then gradually creep back up to faster speeds about a week later. I spoke to Zen and they claimed that something last hit the line at midnight on 15/2 (it has also happened about 8 other times this year) - I wasn't using the computer or on the phone, so could Sky be to blame? Has anyone experienced problems with Sky affecting broadband speed?
The master phone line has a filter with Sky and the telephone (both plugged into the filter!), and upstairs and extension box with another filter which the modem is plugged into.
FYI my latest stats are:
Upstream 448
Downstream 4736
US Margin 23
DS Margin 9
Help does anyone know if Sky could be to blame or any ideal how to get my speed problems fixed?
Old 17-02-2007, 7:06 PM   #2
Conspicuous Member
pixelpixel's Avatar
24,034, Level: 37
Points: 24,034, Level: 37 Points: 24,034, Level: 37 Points: 24,034, Level: 37
Activity: 35.2%
Activity: 35.2% Activity: 35.2% Activity: 35.2%
Thanks: Gave 1,617, Got 1,181
Re: Awful internet speeds - Sky to blame?
Welcome,
I have the same problem with Demon and every now and again my connection will just drop. I just believed it was something to do with my usb modem. I have the same setup as you.
How does the extension box upstairs connect ?
Old 17-02-2007, 10:34 PM   #3
robocop's Avatar
5,248, Level: 17
Points: 5,248, Level: 17 Points: 5,248, Level: 17 Points: 5,248, Level: 17
Thanks: Gave 2, Got 15
I'd read this http://www.skyuser.co.uk/forum/speed...onnection.html
Kevin
Muratcan (18-02-2007)
Old 18-02-2007, 2:45 AM   #4
2,773, Level: 12
Points: 2,773, Level: 12 Points: 2,773, Level: 12 Points: 2,773, Level: 12
Thanks: Gave 10, Got 7
Originally Posted by robocop View Post
Thanks for that, helped a bit with my AOL 2mbit connection.
I will try this with my family and friends who are getting slow speeds.
Old 18-02-2007, 12:08 PM   #5
2,545, Level: 11
Thanks for the replies
Pixelpixel - I believe the extension box upstairs just takes a feed from the master socket (not certain though?). I've then got a filter on this and the modem plugged into the filter
Robocop - Had a read through and ran the Optimiser. My speeds have increased from 4736 to 5056 (every little helps!). However within the forum it states "optimising your TCP/IP settings will make no material difference to your connection stability". I think my problem is the connection stability. Any idea how to find out what is making my connection unstable?
Old 18-02-2007, 5:40 PM   #6
robocop's Avatar
5,248, Level: 17
Some more reading
http://www.skyuser.co.uk/forum/view.php?pg=master
http://www.dslzoneuk.net/socket.php
http://www.skyuser.co.uk/forum/cabli...r-results.html
Kevin
