AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Internet Service Providers (ISPs) > Sky Broadband
LinkBack Thread Tools Display Modes
Old 12-10-2006, 10:50 PM   #1 (permalink)
Thanks: Gave 74, Got 68
Using An Antenna Extender cable for Sky BB Router
Sky BB
Has anyone used an 'extender cable' for the wireless router (Negear)?
http://www.netgear.com/Products/Ante...es/Cables.aspx
Is there a maximum length of cable befire the signal deteriotes?
Basically I have the router tucked away in a floor cupboard out of sight and was thinking of bringing the antenna out to get a better reception.
Kevo is offline
Old 14-10-2006, 11:31 AM   #2 (permalink)
Thanks: Gave 2, Got 4
Re: Using An Antenna Extender cable for Sky BB Router
havent used cables from these, cables but used similar cables for outdoor point to point wireless installations. And not had any problems with cables up to 10meters long, general advice is to use as short a length as you need.
might be worth getting such things from a more generic supplier like the link below.
if your going to place aerial outside just ensure you have lightening protector as well.
http://www.solwise.co.uk/
http://www.solwise.co.uk/wireless-cable.htm
Derek22 is offline
Kevo (14-10-2006)
Old 14-10-2006, 11:50 AM   #3 (permalink)
Thanks: Gave 19, Got 8
Originally Posted by Kevo View Post
Sky BB
Hi I use an antenna from Maplins, I think it cost about £12, has 1.5 mtr small dia coax & screw connector for router or PC WI-FI card, works very well, the base is magnetised aswell although in my case it just stands on a shelf.
Mick
mickbirch2000 is offline
Kevo (14-10-2006)
Old 15-10-2006, 5:42 PM   #4 (permalink)
Thanks: Gave 80, Got 390
Here's another supplier of aerials & cables:
http://www.wifi-antennas.co.uk/
crocodile is offline
Kevo (15-10-2006)
Old 16-10-2006, 10:59 AM   #5 (permalink)
Thanks: Gave 65, Got 165
How much room is there in the cupboard?
If you've got 14" height available, screw one of these onto your router instead.
If not, an extension cable upto 5m should be fine... any longer than that and you'll need a 5db antenna aswell.
The Dude is offline
antenna, cable, extender, router, sky
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Best way to connect both cable & antenna? Rbox Interconnects, Speaker Cables and Switches 11 27-07-2006 11:36 PM
MCE with Xbox360 media extender - ROUTER SETUP MoB Windows Media Center Edition MCE 0 27-07-2006 9:49 PM
help neede with Belkin wireless router and extender cutes6 General Chat 0 22-04-2006 1:25 PM
What aerial cable from roof antenna to splitter to sockets? thierry76 Interconnects, Speaker Cables and Switches 2 04-10-2005 7:00 PM
Connect RF antenna cable from Panasonic DVD-recorder to old TV? adlerberth DVD Recorders, Recording and Media 0 21-11-2002 10:36 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
