| The usual SKY BB signal dropping.....
Right, this has been driving me mad for ages, and I have done the usual things, talked to SKY, changed the router channel, turned UPnP off, plugged it all into the master socket to avoid extension wiring,.....and I am still having problems with the signal....several times an hour, the laptop will lose the wireless connection and the router internet light will flash amber or go off leaving me without a connection.
The speeds are low, and I have accepted that, and the stats I have at the moment are:.....I think I am quite a way from the exchange......
ADSL Link Downstream Upstream
Connection Speed 1024 kbps 304 kbps
Line Attenuation 75.0 db 51.2 db
Noise Margin 7.4 db 10.0 db
I just don't know why the router - the Netgear 834GT - keeps dropping the signal or how I can go about stablising it......should I just replace the router....or would a new filter do the trick? They are both pretty old, so they will be my next move if nothing else helps....
I know these questions have been asked time and time again, but I have tried various different things from many different threads and still seem to be having trouble.......I am not sure if the drops out aree completely stopped with a hard-wire ethernet link as i may not have had the laptop connected for long enough, but it does seem more stable.......but it is not practical to have it hard wired at the moment.
Thanks in advance
