Speed drop question?
Old 02-09-2010, 12:34 PM   #1
775, Level: 6
Points: 775, Level: 6 Points: 775, Level: 6 Points: 775, Level: 6
I used to get a DL speed of 5-8mbps. Now I only get 2mbps.
I phoned Sky and they said 2mbps is the best I can get on my line.
Rubbish I said, I used to get 8.
And that was where the conversation ended.
What, if anything can I do?
Old 02-09-2010, 12:48 PM   #2
accyuklad's Avatar
5,570, Level: 17
Points: 5,570, Level: 17 Points: 5,570, Level: 17 Points: 5,570, Level: 17
Activity: 12.4%
Activity: 12.4% Activity: 12.4% Activity: 12.4%
Thanks: Gave 25, Got 276
have you put your broadband line into the test socket behind the master socket
Old 02-09-2010, 12:48 PM   #3
accyuklad's Avatar
5,570, Level: 17
Activity: 12.4%
::. Kitz - adsl troubleshooting .::
if speed improves then you have a internal problem which you after fix yourself
Old 02-09-2010, 1:20 PM   #4
775, Level: 6
Tried that, no better though.
Phoned Sky again, they again said 2 is the best my line can get, they can't increase it. I am 110% sure I used to get what averaged about 5.5 but sometimes (one time) when I measured it was almost 8. I also used to get about 1 up.
They said BT must of changed something at the exchange, not sure if they are just fobbing me off though.
Old 02-09-2010, 5:31 PM   #5
accyuklad's Avatar
5,570, Level: 17
Activity: 12.4%
show your line stats of db att etc
they be in your router
Old 05-09-2010, 10:01 AM   #6
775, Level: 6
Line Stats
Old 06-09-2010, 7:09 PM   #7
accyuklad's Avatar
5,570, Level: 17
Activity: 12.4%
thats correct of what your line can only handle you could try putting your broadband in test socket see if you get a extra 1-2meg if you do get extra speed then you need to remove ring bell wire which means you leave in 2 and 5 wires
