Billy Hunt
Established Member
Just a quick heads up for all those that have either flashed or swapped their V1 routers.
Sky are rolling out a firmware upgrade on all the V1 routers (the white ones)
All routers that fail the upgrade will be investigated as to why it hasn't happened and it won't happen to the ones that have been flashed with the netgear firmware or aren't using the supplied router (obviously)
If there is a genuine reason why it hasn't worked or it killed your router you will get a new one.
If you are found to have flashed the router or are not using it you could have your account suspended for breaking skys T & C's
The upgrade has already started and will be rolled out on a exchange by exchange basis of around 100,000 users a week.
If your using any other router i.e. the black ones you won't be affected
